Dying Problems
Old May 4, 2006 | 08:53 AM
rhodester's Avatar
rhodester
Dying Problems
I know this is a common problem but Around Feb. I noticed my truck die a few times on me when at idle. Just recently its started doing it at any speed and at any time. I think it's the CPS but its been doing since Feb. is it common for the CPS to show problems and last another 4 months? I can still drive the truck, if it dies it starts right back up. When and where it dies is totally random; I've gone over a week w/ out it dying then other times it'll die 3 times in a mile. It's an 03 w/ 38000 miles. Since its under warranty I left it w/ ford for over a week showed no codes so they charged me $85 and gave me the truck back. I've already changed the fuel filter. Any ideas? or is it just the CPS? if i change the CPS and use the blue one will it void my warranty?
Old May 4, 2006 | 09:26 AM
hott-rodd's Avatar
hott-rodd
For $85 you could put one in and know the answer.
Even if it don't fix your problem you have a much needed spare.
IF it fixed the problem, you may be able to get ford to reimbuse you
part cost.
Old May 4, 2006 | 04:54 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome rhodester to Ford Truck Enthusiasts!
…..See you on the boards.
Old May 4, 2006 | 08:17 PM
Lushman's Avatar
Lushman
I would second what Hott-Rodd said. Buy the black one off EBAY and if it fixes the problem tell your local Ford stealer to give you your money back and pay for the CPS sensor!
Old May 4, 2006 | 11:38 PM
rhodester's Avatar
rhodester
I've already ordered the blue one; Will that matter? will it void the warranty?
Old May 6, 2006 | 08:48 AM
Lushman's Avatar
Lushman
I don't know about voiding the warranty, and the debate is stillout there on te blue one, some people love it, some don't. I am planning on a chip from Jody at DP Tuner and he said to stay with the black so that is what I am doing! I have a spare in the glove box.
Old May 6, 2006 | 07:16 PM
fordmanf350's Avatar
fordmanf350
Did It Fix The Problem?because My 95 7.3 L F350 Doing The Same Thing.ps Dous Anyone Know What That Like Air Valve Is For On Side Of Fuel Filter?
Old May 6, 2006 | 07:18 PM
fordmanf350
I Think It Bad Fuel.
Old May 6, 2006 | 07:37 PM
Muktown's Avatar
Muktown
that yellow lever is to drian the fuel out of the filter. turn it and fuel will run out. i suggest hooking a gas line to the end of the factory drain line otherwise you will get diesel everywhere
rhodester's Avatar
rhodester
My new CPS comes in on Monday so I'll let you know. On my motor there's a yellow valve lever that drains the fuels cup Is that what your talking about? Also, I don't think my problem's fuel related because Its been way too long.
Old May 6, 2006 | 07:42 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
that valve stem looking thing is the schrader valve, to bleed off air in the filter canister after a filter change.
Old May 6, 2006 | 07:46 PM
fordmanf350
I Think Your Right On The Fuel Thing Cus I Did Every Thing And Still Dous What Your Saying.and No On My 95 It Has A Like Tire Valve On The Right Side I Was Wandering What It Was For ?to Bleed The Air Out Of The Can?
Old May 6, 2006 | 07:47 PM
fordmanf350
What Is The Cps And Were Is It?
Old May 6, 2006 | 07:50 PM
fordmanf350
Mine Has 189000m On Her And Runs Fine But That Dying When Take Off Once And Awile And When Going 75 It Like A Burp.
Old May 6, 2006 | 07:53 PM
fordmanf350
Right On Stokin Thats What I Thought And I Think That Will Fix The Dying And Burps.do Yo Bleed When Running?i Think So So I Am Going To Do That In A Min.
