My search found a few of you have had the same problem. Tried mounting my power booster using the CPP 'bolt on' mounting bracket. Well it will mount to the original brake pedal bracket and frame. However the linkage between the booster and brake pedal is off by 1.5" and won't align. Does anyone have an actual picture of a completed install. The kit I have is this one:
I'm considering cutting off the end of the bracket that mounts to the frame and simply welding it to the end of the stock brake pedal bracket. Anyone done anything else with this?
Take a look at my gallery - booster & m/c install - There is a picture of my hook up
of the brake pedal. Hopefully it may explain the problem your having. Good luck.
Gusso, a little off topic but very related, is the duel booster that you are running a 7" or 8"? I am looking for someone with driving experience with a 7 inch duel booster. I currently have a duel 8" from an S-10 including the master cylinder. I used my original stock pedal and fabricated my own brackets. It is much tighter in my 49 than your pix. There is one pic in my gallery looking forward. What you can't see on the photo is how close the rear of the booster is to the aftermarket trans crossmember.
I but one on my 48 and have no trouble with it.Every thing lines up ok.Make sure you have every thing on the way it should go.If I remember right I had the main bracket on wrong the frist time and had alingment problem turned it over and it worked fine.Good luck.
Art
Gary
Gary - Great pics thx and yes thats exactly the problem I am having. It looks like yours even with the spacer is angling the pushrod to the booster. Any issues with it so far? I was thinking it needed to be fairly straight. Mine would need about 3 of those spacers to be straight.
As a matter of fact, the pushrod is very straight. The spacers came with the kit.
(kit is CPP kit via Sacramento Vintage Ford). May Want to look at your brake pedal
bracket and see if all is well there. The brake pedal is on a bolt and maybe something
is broke or out of alignment there. Do you have an automatic xmission or standard?
Maybe the clutch pedal is throwing the alingment off. Good luck - Gary
49willard - Bill,
Yes. It is a 7in Booster. I don`t know if the 7" booster is any longer than your
8" S-10 booster. If you need to know I`ll be happy to measure it for you.
I have had no problems and highly recommend a dual booster for safety reasons.
Power steering and power brakes make all the difference. You will be very happy
with yours. Good Luck - Gary
Thx guys I'll check it out again. Its a C4 and the clutch pedal has been removed the brake seems to be positioned correctly up against the bracket on the frame. I was about 1.5" to the left of the brake pedal linkage point so I never considered the (1) spacer I got with my kit. Gary's pictures give me something to work from anyway.
Hi Scott Just checked out your web site, and what a nice one you have. The pictures are great. Do you do all the panting yourself there? Also I saw the childs hand prints on the side of your truck, made me wonder if my grandkids were thereLOL It looks that you may be done with it not to long from now. When is all done and you want to take her out, just remmber where Warsaw, Tx is and come on out and take a ride out in the country.All the M/C groups, and old car groups use FM148 almost every weekend Take care
is it possible during the C4 swap and clutch pedal removal a spacer on the original shaft was not reinstalled, changing the position of the brake pedal?
just a guess...
just a guess...
i think you will get it all figured out though!!
Doesn't this look right? The brake pedal is lined up correctly inside the cab.
49willard - Bill,
Gusso,
I would like to know how deep your 7 inch booster is. My 8" is 6" flange to flange.
Thanks
Gusso, a little off topic but very related I am looking for someone with driving experience with a 7 inch duel booster. .
While not exactly what was asked, I am running a single diaphram 7" booster with the complete brake system from the donor 87 Town Car and if they worked any better, my new windshield might have a few nose prints on it. I couldn't ask for a better balanced brake system.
It`s now 9:15 pm Sac time and I just got on forum. I`ll measure booster for you
in the am, and post sometime in the morning. Sorry for the delay, I`ve been
trying to fix some electrical problems on my `56 and was not able to get on forum
until just now. Any one have a magic wand that will fix electrical problems? lol
The booster is 5 3/8" long. Measured from the booster mount bracket
to where the m/c bolts to it. The m/c is 7 3/4" long, for a total of 13 1/8"
Hope this helps. I was wondering, if you made your own bracket, would it be
possible to move it forward a little or re manufacture a new bracket to get you a little more room? Anyway goods luck with it.
