Terminator Vs. Pulse?
Old Apr 13, 2008 | 09:39 PM
stroken's Avatar
stroken
https://www.dieselsite.com/index.asp...ROD&ProdID=827
Found that while searching the internet tonight..how does it compare to the terminator? I know its half the price...but the terminator is two HPOP, what if you bought two pulses' and used them both? think it would work? more or less oil then the terminator? thoughts on this? pros? cons? just an Idea I though Id throw around!
Old Apr 13, 2008 | 09:43 PM
justblowin'smoke's Avatar
justblowin'smoke
the pulse is designed to take the place of two pumps i like the idea also check out the stealth pumps that are coming out they have three stages to chose from they are single pumps also but unlike the pulse they are completely new design instead of modified stock pumps like the pulse
Old Apr 13, 2008 | 09:44 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
If you plan on anything except a HUGE injector over a stock B code, or basically any B code bigger than stock, the pulse is what you would look into. I was looking into the pulse and some plans are changing. My theory is that you don't need the volume of two entire pumps for 90% of the setups people out there are running. You just need more than one. If a terminator is 2, the stock is 1, i'd say the pulse is 1.6 or 1.7. Joey at Term. does modify a stock 17* hpop into something along the lines of a 1.2 or 1.3 i'd say.
Old Apr 14, 2008 | 10:29 AM
aklim's Avatar
aklim
I got a BTS dual pump setup because I have a feeling that someday I am going to kick myself if I didn't get a dual pump and I needed it.
Rusty_S
Electrical Systems/Wiring
Aug 18, 2013 01:30 PM
Talyn
19
Sep 15, 2011 08:18 AM
bradahl
1997 - 2003 F150
Oct 2, 2009 01:25 PM
Woodsman_30350
Oct 2, 2008 10:07 PM
RaleighDad66
Jun 29, 2005 09:41 PM
