No Throttle or dash gauges.
Old Apr 13, 2008 | 08:17 PM
lvseicsh's Avatar
lvseicsh
I drove my truck to the Ole Miss vs LSU baseball game yesterday. When I left the game to come home, I started the truck, put it in reverse, backed out of the parking space, put it in drive and then "NO THROTTLE".
I have NO throttle response, but the engine and tranny work just fine. If I push the pedal to the floor I get nothing but idle. Luckily I have a DP tuner and opted for the "high-idle" setting that's around 1200rpm. I was able to take backroads all the way home.
I've noticed that none of the gauges are working on my dash (speedo, tach, fuel, engine temp, etc.). I do get a few lights, but not all of them.
Do y'all have any idea what I should check first?
Thanks,
Old Apr 13, 2008 | 08:24 PM
megawatt00's Avatar
megawatt00
I'd start with the basics, fuses. I don't have my manual with me right now. But I do beleive that there is one for the throttle.
makomaker's Avatar
makomaker
I know your first problem.... you're a hoddy toddy!! Geaux to hell Ole Miss!
Seriously, I will analyze your post and re-post, but I had to get this in here for the record.
Old Apr 13, 2008 | 08:29 PM
makomaker's Avatar
makomaker
check fuses.
Old Apr 13, 2008 | 08:41 PM
bigsteve1969's Avatar
bigsteve1969
i 2nd the fuses
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Leo, our trucks are (fly by wire), we don't have a cable going to the carb like a gas engine of old days. We have a sensor that tells the PCM where the pedal is at a given time as you press down on it. I have seen many post about this. If it is not a fuse, you will have to buy a whole TPS to fix this.
I hope it is just a fuse. Good luck.
Old Apr 13, 2008 | 08:47 PM
lvseicsh's Avatar
lvseicsh
Man, you guys are fast. I thought it might be my fuses since the dash gauges didn't work.
Old Apr 13, 2008 | 08:51 PM
lvseicsh's Avatar
lvseicsh
I'll let y'all know tomorrow.
Old Apr 13, 2008 | 10:03 PM
nhill2090's Avatar
nhill2090
on my truck, that is fuse #19 that controls those. Your 01 may be different
Old Apr 13, 2008 | 10:25 PM
distortedcloud's Avatar
distortedcloud
this happened to me last night. It turned out to be a fuse, it'll be #19 and a 10amp mini fuse.
Old Apr 13, 2008 | 10:42 PM
PaysonPSD's Avatar
PaysonPSD
That's the kind of post we're looking for. The exact same problem and the fix. Reps to you.
Old Apr 13, 2008 | 11:10 PM
nhill2090's Avatar
nhill2090
Good catch. Great minds think alike
REps sent
Old Apr 14, 2008 | 05:24 AM
pressureman's Avatar
pressureman
Yep, I 2nd the 10A red mini fuse #19. I found a bare wire in my steering column at the base of the shifter. You can put a little tape on it, or you can replace the shift lever itself for about $45 from the dealer. The wire I found chafed controlled the OD. Hope this helps..
Old Apr 14, 2008 | 07:15 AM
lvseicsh's Avatar
lvseicsh
I'm going outside to change/check it right now.......I've never been associated with such a great forum.
Old Apr 14, 2008 | 07:45 AM
lvseicsh's Avatar
lvseicsh
It Worked......thanks.
