4-way flashers? dumb question.
Old Apr 13, 2008 | 07:28 PM
Old Ford Blue's Avatar
Old Ford Blue
I'm pretty sure my 67 has them as I found a second flasher module, but I sure as heck can't find how to turn them on.....
Thanks in advance.
Old Apr 13, 2008 | 08:55 PM
Ford_Six's Avatar
Ford_Six
A switch in the glove box if it has a manual choke, or on the lower dash next to the lighter if it has an automatic choke.
Old Apr 14, 2008 | 02:37 PM
Old Ford Blue
In the glovebox, huh? Ok, I'll look, since I've got a manual choke. It wouldn't happen to be what looks like a glovebox light switch would it?
Old Apr 14, 2008 | 06:38 PM
mk's Avatar
mk
It'll be a toggle switch fastened to the top right or left side of the glove box liner. The only exception to this from 67-9 I'm aware of is that with a/c it was necessary to move it under the dash by the steering wheel. The 70-72 trucks had a pull switch located to the right of the column.
mike
Old Apr 14, 2008 | 07:41 PM
Old Ford Blue
Ahhh, ok I gotcha, I'll check in a bit....
