Sponsored by: Real Truck
2007 alignment trouble
Old Apr 13, 2008 | 04:58 PM
Turbokid15's Avatar
Turbokid15
I am just curious if any body else is having problems with the front end of there trucks being out of alignment. On my dads truck the top of the tires are out more than the bottom causing the outside of the tires to wear. Keep in mind the truck only has 22,000 and some change miles. It has not been modified at all so I am guessing it is something from the factory.
Old Apr 13, 2008 | 05:05 PM
redford's Avatar
redford
FTE Leadership Emeritus
No, I have 33,000 on my ,07 and have not had any issues with alignment or uneven tire wear.
Is it just the outside edge or both edges that are wearing?
Old Apr 13, 2008 | 08:05 PM
DCSpecial's Avatar
DCSpecial
Didn't really have any issues with my 07, but I rotate my tires every 6k or so and had it aligned at an independent shop at 17k, definitely handles better after the alignment.
Old Apr 13, 2008 | 08:17 PM
carls 250's Avatar
carls 250
had to have camber bushings installed to get alignment to specs i only have 18k & never been off road. Only mod is 2'' leveling blocks in front.
Old Apr 13, 2008 | 08:33 PM
DCSpecial's Avatar
DCSpecial
With a 2" leveling kit, I'm guessing they installed new cams/bushings to correct the caster.....not the camber.
Camber isn't effected by the leveling kit, but caster does go closer to 0* (more negative) with a leveling kit.
The caster cams are included with some leveling kits for that reason.
Old Apr 13, 2008 | 08:57 PM
Turbokid15's Avatar
Turbokid15
I will get some pics tomorrow of the tires and then maybe somebody can tell me if the truck needs to be realigned and the tires replaced or rotated.
Old Apr 13, 2008 | 10:26 PM
DCSpecial's Avatar
DCSpecial
If it's a 2wd, I would definitely have it aligned with those miles on it.
Old Apr 14, 2008 | 06:52 AM
redford's Avatar
redford
I'm wondering why you wouldn't want to have your truck aligned and tires rotated? It's normal maintenance.
Old Apr 14, 2008 | 07:09 AM
pagnew's Avatar
pagnew
Yup - I rotate them tires every 5K.
Old Apr 14, 2008 | 08:18 AM
Turbokid15's Avatar
Turbokid15
I talked to my dad this morning and he thought when he took it to ford for the oil change they did it there as routine maintenacne.
Old Apr 14, 2008 | 08:28 AM
pagnew's Avatar
pagnew
Sometimes they have a special 'works' maintenence pkg that includes that, but usually the tires don't get included in normal 'oil change' maintenence - at least not at my dealer...
Old Apr 14, 2008 | 09:19 AM
Turbokid15's Avatar
Turbokid15
Here are the pics
The first one is of the passenger front tire it has the chunks taken out on the side and is worn in the middle
The second on is of the driver front tire it is worn on the side only.
The question now is should I go ahead and replace the tires or can I just rotate the tires and have the truck realigned.
Old Apr 14, 2008 | 07:42 PM
DCSpecial's Avatar
DCSpecial
The truck is 2wd, correct?
Old Apr 15, 2008 | 07:28 AM
Turbokid15's Avatar
Turbokid15
Correct 2wd Diesel
Old Apr 15, 2008 | 08:22 AM
redford's Avatar
redford
The "worn in the middle" tire is probably overinflated. Put less air in your tires. The gouge is caused by contact with something.
The "worn on the side" tire may be an alignment problem, a suspension problem (worn ball joints) or an underinflated tire (if the inside and outside are worn, can't tell from the picture).
