Cam thrust issue...
Old Apr 13, 2008 | 04:36 PM
v8xploder's Avatar
v8xploder
Cam thrust issue...
I just installed a comp solid roller cam in my 460. I was checking the thrust clearance with a dial gauge. I pushed the cam back as far as i could and zero'd my gauge and moved the cam as far foreward as i could. It moved .023, this is without the timing gear installed. Is this too far? I have a book that says under .005 is max.
Old Apr 16, 2008 | 08:14 AM
385seriesHemi's Avatar
385seriesHemi
Yeah id say thats too far. Thats over 4 times as much as the spec allows.
Old Apr 16, 2008 | 11:02 AM
fasthauler's Avatar
fasthauler
Check the thrust plate for wear. Turn the thrust plate over and try it again. I have had the same problem before with aftermarket cams.
Old Apr 18, 2008 | 07:59 PM
v8xploder's Avatar
v8xploder
I did not have the timing gear installed, would that make any difference? I think the thrust plate only goes on one way, dummy proof....
Old Apr 18, 2008 | 09:41 PM
brh1969's Avatar
brh1969
Doesnt Comp recommend a roller thrust plate with their roller cam?I dont remember for sure.
Old Apr 18, 2008 | 10:13 PM
v8xploder's Avatar
v8xploder
I figured out my problem. I had only tapped that cam gear on with a soft hammer. Once I snugged down the bolt she came tight to the cam, now a perfect .005 whoops
66v8baby
Dec 8, 2016 08:33 AM
83Van
May 19, 2015 05:17 PM
richsoucie
Mar 3, 2009 10:15 AM
ENCSDEI
Apr 29, 2007 03:47 PM
Rico82nd
13
Oct 28, 2003 08:01 PM
