97 460 idle speed?
Old Apr 13, 2008 | 02:21 PM
SuperFord's Avatar
SuperFord
97 460 idle speed?
Does anyone know what the idle speed on a 97 f250 460 efi should be at? Mine runs at about 900 rpms in drive. I have not done anything that would change it. Also what should I have the timing set at? I am going to check this as well.
Old Apr 13, 2008 | 06:59 PM
c_rossman's Avatar
c_rossman
This sounds about right to me. The computer controls the idle. Unless you have a bad IAC or vacuum leak it should stay within 800-900rpm unless cold. What is the idle in nuetral or park?Timing should be 10-12 degrees BTDC with the spout connector removed.
bakos
Nov 18, 2013 04:14 AM
79bigblock
Nov 18, 2010 10:28 AM
97powerstrokeman
May 17, 2009 09:46 AM
dogbreath1000
Jul 10, 2008 09:56 PM
crescentwrencher
Apr 4, 2008 08:37 PM
