Idle on a 460
Old Nov 17, 2013 | 03:29 PM
bakos's Avatar
bakos
Idle on a 460
97 f250 460 auto
Idles 1000 to 1100 when warm, seems a tad high to me for drivability. Should I adjust it and to what?
Recently went back to stock throttle body from bbk. Might have lost a little snoose but seems to drive better / doesn't kick down on freeway near as much and mpg might have increased.
Old Nov 17, 2013 | 04:23 PM
Lead Head's Avatar
Lead Head
Warm the engine up, unplug the idle valve, and then set the idle to just high enough that the engine can barely keep it self running. So probably 450-500 RPM or so. Then plug the idle valve back in.
Old Nov 17, 2013 | 05:34 PM
danr1's Avatar
danr1
Sounds like its sucking air, idle is not adjustable it is computer controlled.
Set screw on throttle body is a stop screw, prevents plates from digging into the throttle body fully closed.
Stop screw should be sealed in place, if appears its been tampered with then yea it needs properly set back to its original position.
Old Nov 17, 2013 | 05:55 PM
Conanski's Avatar
Conanski
Yeah that set screw on the TB is not supposed to be touched, idle speed is cntrolled by the computer but it must get accurate throttle position data and the Idle bypass valve must be operational and not clogged or sticking, so look into those 2 devices first.
Old Nov 17, 2013 | 07:03 PM
bakos's Avatar
bakos
New tps - and the stop screw looks like it's been messed with - if I remember rite when I switched the TB the butterfly's were cracked open a tad
I do not know what or where the idle bypass is - I'll try and look it up
What would be the idle rpm I'm looking for?
Old Nov 17, 2013 | 08:49 PM
Lead Head's Avatar
Lead Head
about 750 warm park, around 650 in drive or so.
Old Nov 18, 2013 | 04:14 AM
mgroshong's Avatar
mgroshong
My f250 460 truck has the same high idle roughly 1000 rpm in park and around 750-800 in drive. This just seems high to me as other trucks we own ( 01 yukon) idle around 5-600.
sandymane
322
Mar 24, 2017 07:36 PM
icrman
Jun 19, 2008 07:50 PM
sdnorden
Jan 19, 2004 07:23 PM
paleryder
1978 - 1996 Big Bronco
Sep 30, 2002 12:11 PM
mjb1962
Feb 23, 2001 11:29 PM
