Sponsored by: Real Truck
Tire pressure
Old Apr 13, 2008 | 08:18 AM
FORDSDOWNER's Avatar
FORDSDOWNER
Tire pressure
LT275/65R20 E
The tire calls out for MAX 80 psi cold, would running 60 PSI cold unloaded be ok?
Thanka for the replys.
Old Apr 13, 2008 | 08:29 PM
high ho silver's Avatar
high ho silver
Yes you should be fine. The max posted on the tire is for a full load. It will ride better as well.
Old Apr 14, 2008 | 09:46 AM
John M T's Avatar
John M T
Ford calls for 60 psi that's to make the truck ride softer
the tires say 80 psi, that's the max for towing an m/t truck would ride very hard at this pressure.
I settled on 70 psi, it's a good comprimise for me
also the higher the psi, the better mileage, BUT, the tires would wear unevenly due to over inflation. too low on the psi does the same.
so 70 psi is good. that's cold psi when hot they will be 2-3 psi higher
Old Apr 14, 2008 | 10:03 AM
redford's Avatar
redford
FTE Leadership Emeritus
Be careful about taking recommendations from other owners, every truck is different. You need to experiment to find your sweet spot.
For instance, I am still running the stock 265/70-17 BFGs on my truck, 75 PSI recommended all around. If I lower the pressure to 65 PSI I start to see steering wheel oscillation/wobble after hitting a bump. Lowering the pressure to 60 PSI makes the wobble worse. 70 PSI gives me a decent ride.
Ford does not recommend running anything other than what the door sticker recommends, depsite what others might tell you. In fact, if you take the truck into a Ford dealer to have the "death wobble" problem fixed, the first thing the technician will do is check your tire pressure and inflate to door sticker pressure, per the Ford TSB.
Old Apr 14, 2008 | 10:08 AM
1buzzbait's Avatar
1buzzbait
-------if yer tires have a MAX rating of 80--and you run 80, you are NOT running overinflated!!
Old Apr 14, 2008 | 01:11 PM
redford's Avatar
redford
He's talking about over and under inflation based on the weight of the truck, not exceeding the MAX PRESSURE recommendation on the sidewall.
It all depends on how much weight the tire is supporting. If you run the tire overinflated, the center will have contact with the asphalt, the sides will not. If underinflated, the sides will contact the asphalt, the center will not. If inflation is correct you get the maximum contact patch.
One thing to keep in mind, the pressure for a correct contact patch is a range, not a specific number.
epdukes13
2009 - 2014 F150
36
Jul 31, 2025 09:22 PM
kx450frider617
Dec 29, 2013 08:41 AM
BVR PLZR
All Things Towing
17
Aug 30, 2012 06:34 PM
hatchet
Jan 15, 2008 03:24 PM
ScottInTexas
46
Sep 25, 2007 11:08 PM
