Rods
Old Apr 25, 2002 | 05:27 PM
td351w's Avatar
td351w
Rods
How much horsepower can stock rods from a 351w HO handle? Thanks
Old Apr 25, 2002 | 06:23 PM
sauerf100s's Avatar
sauerf100s
Rods
Others might have a different opinion, but it isn't horsepower that is the limiting factor on a stock set of rods. It's actually RPM's. It's hard to put an exact figure on how many RPM's a stock set of rods can take. Lighter weight pistons will help them take more, as will a good set of ARP rod bolts. 6000 RPM's is a pretty good speed not to exceed for any length of time with a stock set of rods on a 302. The longer stroke of the 351 may lower this "safe" speed a little bit.
Old Apr 26, 2002 | 07:14 AM
airharley's Avatar
airharley
Rods
If you didn't know the stock rod length is 5.596". I have been tring to find the answer to your question for a little while. I am setting up for a stroker motor. I want to do it right and run it for a while until "I decide when" to change things around on my engine. Not the other way around.
Old Apr 26, 2002 | 10:07 AM
lanero's Avatar
lanero
Rods
Daniel92f250
Dec 17, 2013 09:11 PM
veedogtoo
Dec 19, 2012 07:39 PM
ranger1985
Jun 19, 2010 07:57 PM
jesuscowboy
Jul 16, 2009 03:44 PM
father/son
Oct 18, 2007 10:27 AM
