service engine light on
Old Apr 12, 2008 | 09:00 AM
whiteywhip's Avatar
whiteywhip
well a while ago when it was raining this light came on...it ran like it was falling on its face....was recommended here to use dioelectric grease on the cam postion sensor plug...did all the sensors with the grease...nothing...changes the cam position sensor...nothing...changed the exhaust back pressure sensor and new tube and cleaned out exhaust manifold before installing ...nothing...new fuel filter...nothing....nothing meaning still running bad....went to garage to pull codes...no codes came up....engine service light only comes on when engine is running...does anyone have any ideas of am i going to the dreeded ford dealer to get this straightened out???.....HELP PLEASE!!!!
Old Apr 12, 2008 | 09:07 AM
F350-6's Avatar
F350-6
Where exactly did you get the truck scanned for codes? Not all scanners will pick up the codes for these engines. If the light stays on it should have a code stored.
Can you describe running bad a little better? Do you mean it sounds / feels like not all your cylinders are firing? If so you may have a loose UVCH plug or some chaffed wires. If you have an ohm meter you can test this by unplugging the 9 pin connector at each valve cover.
The connector at the valve cover has a plug on both the inside and the outside. The one on the inside is usually the one that comes loose. You can disconnect the outside plug and ohm the wires for resistance to determine which side needs to come off. The valve cover gasket is re-usable.
The 9-pin plug is wired as follows:
G G I I C I I G G
G=Glow Plug +
I = Injector +
C= Injector Common
The injectors fire with a 115VDC signal from the IDM. Do Not pierce the wires to test.
Test between "I" and "C" to test the injectors, should be less than 5.0 Ohms.
To check glow plugs Test between "G" and battery ground. Should be between 0.6 and 2.0 Ohms
Here's a link with pictures so you can see what it is you're looking for with the meter.
https://www.ford-trucks.com/forums/2...or-wiring.html
zx250's Avatar
zx250
Of the next Riffraff East
Need to find a garage with a better code reader, one that is designed for our trucks. The average run of the mill reader will not read PSD codes. If the light is on, there is a code. Give a little better description of how it is running now.
Old Apr 12, 2008 | 09:08 AM
zx250's Avatar
zx250
Dang Chris, your typing has improved.
Old Apr 12, 2008 | 09:15 AM
F350-6's Avatar
F350-6
This has happened 3 times today. I'm thinking the stars must be aligned just right or some other nonsense. But I'll take what I can get.
Old Apr 12, 2008 | 09:28 AM
whiteywhip's Avatar
whiteywhip
G G I I C I I G G
G=Glow Plug +
I = Injector +
C= Injector Common
just as you discribed....not running on all cylinders...i have to do as you say and test the ohms with a tester...the garage said he had all the updated code reader but maybe he thinks it can read psd...i have to go and talk to him when i pick it up....i can buy a ohm tester at radioshack ...right??.....thanks for your help
Old Apr 12, 2008 | 09:35 AM
zx250's Avatar
zx250
Well, I can't speak for the other two, but I did fish until 3 am last night and just now finishing up my second cup of coffee.
You said it started while raining, Some here have had problems with water trickleing in around the left side of the windshield. If it gets to some of that electronic stuff there, it could cause all sorts of weird stuff, including computer problems. Get the hose out and soak everything down good and look up under the dash for any signs of water.
Old Apr 12, 2008 | 09:41 AM
F350-6's Avatar
F350-6
You can get an ohm meter just about anywhere. Radio shack, auto parts store, home depot, etc. Most multi-meters have an ohm setting.
You can also do as Barry suggested if you think it is related to the raining. If it's the windshield leaking you may need to remove (unscrew) the under dash fuse panel to inspect the back of it to look for moisture. You can also inspect the drivers front wheel well liner and fender liner under the hood for any cracks or holes. Your IDM is located inside there and if it gets wet it could cause problems.
Keep us informed of what you find.
Old Apr 12, 2008 | 09:52 AM
whiteywhip's Avatar
whiteywhip
there wasnt any water leaking in through the windshield but after reading that post with the wire chaffing on the push rod and the wire harness connector coming unplugged under the valve cover ...it sounds like thats where the problem is....wow you guys are great...thanks for everything
Old Apr 12, 2008 | 10:00 AM
zx250's Avatar
zx250
Good deal, let us know what you find.
Old Apr 12, 2008 | 10:14 AM
whiteywhip's Avatar
whiteywhip
will do....thanks
Old Apr 12, 2008 | 10:02 PM
whiteywhip's Avatar
whiteywhip
so what am i in for when i unbolt the valve covers....is there slack in the harness to get the harness unplugged to get the valve covers off...also how much would it cost for these harnesses or a ballpark figure to have a garage install them...is there a web site to buy it?
Old Apr 12, 2008 | 10:14 PM
F350-6's Avatar
F350-6
The valve cover will lift off and leave the harness on the head so no worries there. The hardest part of pulling the valve covers is just getting to them. You may just have a loose plug and no chaffed wires. You can make a shim, I've even seen one made out of a quarter, to keep it plugged in. If you need a new harness they're cheaper from an International dealer then they are from Ford.
Have you tried the Ohm meter yet? No point in pulling off the wrong valve cover.
Old Apr 12, 2008 | 10:52 PM
whiteywhip's Avatar
whiteywhip
got too many projects going...the roadrunner and the truck...going to buy the tester tommorrow...ok i am going to unplug the harness from the valve cover and test the pins in the valve cover ...right??...and also test the unpluged one too
Old Apr 12, 2008 | 11:18 PM
F350-6's Avatar
F350-6
Just test the pins that stay in the valve cover. If you want to check the unplugged wires you'll need to dig into your drivers fender to find you IDM and check for continuity, but that's not a common problem.
