New injectors same old problem....
Well, #'s 1,3,5, and 8 were off when I installed them, and a week later although they've have improved, they're still off. 1,3,and 5 aren't as bad as 8- 8 is right about 4.5% at stock setting on DP Tuner, where as the other 3 are about 0.1% - 2.0%.
I just wish I understood what the hell those percentages mean?? Once I know what they mean, what could be causing them to go off?? I do know in the past, maybe 6 months ago or so, they were always at 0.0%. If the engine wasn't idling somewhat goofy I wouldn't mind too much, but for what I spent to fix the problem, and still not have the problem fixed, it get's kinda frustrating.
The only thing I can think of is that maybe the crap that was on my old injectors is still in the fuel system and possibly cloggin my new injectors?? Or is it an oil problem? She's got 196,000 miles on her btw.
HELP!!!!
Beer boy- I had # 6 and 8 running off before the R&R, and that was with the original CPS. When I took it in to get it checked, they installed the new "blue" one as part of the recall. I don't see how that would effect just some of the cylinder, although if that could be a problem, I do have an old one in the glove box I could try.
Chart 6
Unique Idle Concerns: Rolling Idle, Stalls When Engaging Clutch
Runs Rough: Idle
Note: Perform the following preliminary checks:
Check engine oil level.
Confirm oil change within 8,046.5 km (5,000 miles).
Check air intake system: Air Filter Minder
Confirm acceptable SAE oil viscosity and API rating of oil.
Check fuel quality. Refer to Section 4A or Section 4B .
Confirm correct dipstick part number.
SYSTEM/COMPONENT REFERENCE (Section 5 Pinpoint Test unless noted)
Perform KOEO On-Demand Self Test GO to the appropriate pinpoint test if fault is indicated.
Perform KOEO Injector Electrical Self Test GO to the appropriate pinpoint test if fault is indicated.
Check For Aerated Oil GO to Section 4A or Section 4B , Diagnostic Subroutines, Performance Diagnostic Procedures. PERFORM Injection Control Pressure Test.
Check Source Of Aerated Oil OVERFILL the engine with 1.9 L (2 quarts) of the specified oil. RAISE the rear of the vehicle approximately 25 cm (10 inches). RUN engine at WOT for 180 seconds. If ICP is greater than 12.4 mPa (1,800 psi) or 1.75 V oil is aerating due to lack of defoaming agents, CHANGE engine oil and RETEST. If it is less, REPAIR O-ring or pickup tube leak. REFER to the Workshop Manual, Section 303-01.
Injection Control Pressure Test GO to Section 4A or Section 4B , Diagnostic Subroutines, Performance Diagnostic Procedures. PERFORM Injection Control Pressure Test.
Low Idle Stability Test GO to Section 4A or Section 4B , Diagnostic Subroutines, Performance Diagnostic Procedures. PERFORM Low Idle Stability Test.
Check For Biased ICP Sensor GO to Pinpoint Test DC .
Check Fuel Pump Pressure GO to Section 4A or Section 4B , Diagnostic Subroutines, Performance Diagnostic Procedures. PERFORM Fuel Pump Pressure Test.
Check Lubrication Pressure REFER to the Workshop Manual, Section 303-00.
KOER On-Demand Self Test GO to Section 4A or Section 4B , Diagnostic Subroutines, Performance Diagnostic Procedures. PERFORM KOER On-Demand Self Test. If DTC 1211 is present, GO to Section 4A or Section 4B . MONITOR ICP while cranking (9C). If no DTCs are present, GO to Section 4A or Section 4B , KOER Cylinder Contribution Test.
Check Pressure Balance PLUG high-pressure hose for right cylinder head using Adapter for 303-S626. RECORD IPR at specified rpm (F650/750 2,500 rpm, all others 3,000 rpm). PLUG high-pressure hose for left cylinder head using Adapter for 303-S626 and REATTACH high-pressure hose on right cylinder head. RECORD IPR at specified rpm. If IPR duty cycle difference is greater than 2%, GO to Check For Leak Source. If it is not, INSTALL a new IPR.
Check For Leak Source REMOVE valve cover on cylinder head with higher IPR reading. With engine idling, LOOK for bubbling around injector bores or oil gallery drain plugs. Or, with engine off, ATTACH approximately 689 kPa (100 psi) air pressure to high-pressure oil gallery. REMOVE injector spill spouts for visibility. LOOK/LISTEN for leaks. If a leak is present, INSTALL new seals on injectors or RESEAL oil galleries as required. If not, GO to Section 4A or Section 4B , Diagnostic Subroutines, Performance Diagnostic Procedures. PERFORM KOER Cylinder Contribution Test.
Check Rough Idle If rough idle was present when vehicle was new or after installing a new high-pressure pump, CHECK high-pressure oil pump. If not, PERFORM KOER Cylinder Contribution Test.
Check High-Pressure Oil Pump ATTACH right hose to left head and plug left hose. CHECK IPR at idle. COMPARE this reading to the reading for left head in Step AF12. If difference in readings is greater than 0.2 V or 2%, imbalance is caused by high-pressure oil pump. CONFIRM high-pressure hoses are clear and INSTALL a new high-pressure oil pump. If not, GO to Section 4A or Section 4B , Diagnostic Subroutines, Performance Diagnostic Procedures. PERFORM KOER
Check For Engine Wear GO to Section 4A or Section 4B , Diagnostic Subroutines, Performance Diagnostic Procedures. PERFORM Crankcase Pressure Test. If crankcase pressure is higher than 5.6 mm Hg (3 in H 2 O), REPAIR engine as required. If not, INSTALL a new injector in identified cylinder.
Check For Incorrect Injector Application REMOVE engine valve covers. CHECK part number stamped on top of each injector. If the correct injectors are installed, then cause of rough idle cannot be determined. COMPARE idle performance with other vehicles. If the injectors are not correct, INSTALL new injectors
Key On Engine Running (KOER) Cylinder Contribution Self Test is a functional test of the PCM performed on-demand with the engine running, A/C off and engine oil temperature above 21°C (70 °F). This test will determine if all cylinders are contributing equally to engine performance. The PCM will test all 8 cylinders continuously during the test; there is no change in engine speed or operation that can be detected by the technician. The test checks for cylinder-to-cylinder changes in engine rpm, and sets a code if the rpm change is not within a pre-calibrated range. The test checks for weak injectors or low compression cylinders. A fault must be present at the time of testing for the KOER Cylinder Contribution Self Test to detect a fault, so the engine operating condition at which the idle is the worst will produce the best test results. For automatic transmission vehicles, the best results are reached with the parking brake set and the transmission in DRIVE. If a fault is detected, a Diagnostic Trouble Code (DTC) will be output on the data link at the end of the test when requested by a scan tool. Only a hard fault code (DTC) will be displayed.
Also don't forget the simple things like clean full oil & clean filters.
Also, I could probably change my main engine filter and try it then, I can't remember the last time I changed it, but I do use a BIG Napa (IIRC) 3384 fuel filter on my Vormax, which is rated at 2 micron, and I change that when it builds too much vacuum. Cheaper than changing the main filter ($19 vs. $30+) and better filtering.
just for craps and haha's. are you able to do a compression check.
will the predator do most of those tests?
I actually changed my oil twice after I changed the injectors- once right after the install and a few miles of driving, and then again the next day. I think however tomorrow I'll changed both fuel filters just for GP. The NAPA 3384 cost about $19 and the stocker is about $35 or so.... cheap insurance for piece of mind!
Maybe my IPR is going out?? I do have 196,000 miles on her...
I have not done a CCT on mine since returning from Smokin. I would not be surprised if a couple failed that but I don't care. I have swapped them enough. It did well on the dyno so I may be done with them. If I find something I will let you know.
BTW, that overfilled oil is a no go. That can make it poopy too.
Like you mentioned, a couple may fail (what's the range for failing??) but it still runs fine. Maybe I can take a video w/ the wifes digital camera and post it or something, but I think it's like you said, the nature of these injectors.
And tomorrow I'll drop that extra quart w/ the fumoto valve. Mongo no like poopy truck!
