Sponsored by: Auxito
how do you remove u joints
Old Apr 11, 2008 | 07:25 PM
40LUTZAG's Avatar
40LUTZAG
What is the best way to remove u joints on my 4x4 f-150. I got looking under they look pretty bad, the squeek too.
Old Apr 11, 2008 | 08:48 PM
sclariat's Avatar
sclariat
you can buy a tool like this one: Harbor Freight U-Joint Tool
It makes the job so much easier.
Old Apr 11, 2008 | 08:53 PM
99whiteford's Avatar
99whiteford
I read in another post where you asked if you removed the bolts or just used needle nose pliers.remove the bolts where the driveline bolts to the rear end.this will let you get the shaft out where you can work on it.If you've never done this before ,,get some help.I have seen guys destroy a drive shaft trying to get the u-joint out.I generally use my shop press and push them out.
Old Apr 11, 2008 | 09:05 PM
sclariat's Avatar
sclariat
Oh my yes! You definitely need to remove the drive shaft from the truck. Also have to agree with 99wf that this can be a tricky procedure. If you're not sure, pay to have it done. It's not a super costly repair.
Old Apr 12, 2008 | 03:52 AM
BlueOvalFitter's Avatar
BlueOvalFitter
Thumbs up
Replacing u-joints is a very simple job.A few tips;
1) Mark the pinion flange in relation to the driveshaft flange before removal.
2) Soak the bolts with a good penetrant before removal.
3) A (8" or bigger) c-clamp is very helpful.
4) Buy u-joints with grease zerks.
5) Stick with name brands; Dana/Spicer,Neapco
Old Apr 12, 2008 | 06:17 PM
DaninMO's Avatar
DaninMO
Best way to remove u-joints? With a hammer!
Old Apr 12, 2008 | 06:22 PM
Greywolf's Avatar
Greywolf
FOR CHRISSAKES MARK THE SHAFT TO YOKE ALIGNMENT!
I know - it seems like a little thing, but the reason for it is to keep everything in balance. Lot's of tech articles lately are stressing that, possibly due to odd manufacture. If you have one that wears out quick, try rotating it 180 degrees, it may have been reversed.
Old Apr 12, 2008 | 08:24 PM
xtrford's Avatar
xtrford
Nice to see you over here on the flip side Wolf.
Old Apr 12, 2008 | 08:35 PM
Greywolf's Avatar
Greywolf
I've always been flippant.
Once U-JAYS are in place, it's a good idea to slam them with a mallet in all four directions to free them up - then grab the yoke and move them around by hand to see if they bind. If they bind - slam them again in that direction and re-check.
A well installed U-JAY rolls smoothly on all axis.
Be sure they are packed well with greese, and repack them if they have to be "ABUSED" to get them to roll right.
DON'T forget to install the grease nipple - if there IS one.
If a cup on a U-J doesn't go in - DO NOT force it. A needle bearing may be out of place - check it by taking it apart before forcing it. A common tell is that the joint is about a circlip distance away from going in and it binds there. This usually means a needle bearing is under the shaft - because the needle bearings are the same thickness as the circlip.
One of them fell out somehow...
Old Apr 12, 2008 | 09:15 PM
81 green machine's Avatar
81 green machine
ya and depending on what year truck you have"hammers"work well but so do propane torches if u have the ceramic sealed ones have fun there not that bad,make sure u have a solid surface to pound against!
Old Apr 12, 2008 | 09:20 PM
Greywolf's Avatar
Greywolf
Doesn't a torch burn the grease?
But then - you are talking pulling OUT.
I was saying install...
Old Apr 12, 2008 | 09:31 PM
xtrford's Avatar
xtrford
You should use a 12 sided (inside) socket instead of a hex style found in most tool boxes....I do believe it is a 12 or 13mm from years back when I did mine.
Old Apr 12, 2008 | 09:58 PM
Greywolf's Avatar
Greywolf
Some of them are twelves, a six point gets a better grip on the flats.
A rounded bolt is a pain - use what works. Never ruin a fastener if you can avoid it.
You may find on newer machines that there is a mix of metric and standard. Go with the best fit - because if you don't you'll have a pain in the butt on your hands! A big problem with ford is the reluctance to go all the way metric. You never know what you'll find. Get a close fit, or DON'T CHANCE IT!
A six point WILL NOT WORK on a twelve point fastener
Rear yokes are generally 10 or 11 millimeter, unless an old axle is in place. Nine inches use standard (USA) sizes. 3/8 or 7/16 should fit.
If all else fails use a grinder and take out what is left with vice grips.
Old Apr 14, 2008 | 07:25 PM
81 green machine
ya i was talking extraction,sorry i dont have a pic. they may not be ceramic exactly but there some knd of injected "stuff" i was told ceramic.they have pin holes in the yokes,where the factory injects it in. but u just use the keepers/snaprings when u put the new ones in.
weez440
Apr 17, 2017 09:21 PM
mofoco1
Dec 1, 2015 12:00 PM
Salsa91
15
Jun 10, 2015 11:10 PM
$undance
1997 - 2003 F150
Jun 12, 2012 03:34 PM
Broncobirdy
1978 - 1996 Big Bronco
Jan 27, 2006 02:46 PM
