check engine light
Old Apr 11, 2008 | 05:53 PM
madcatter33's Avatar
madcatter33
Smile check engine light
Ok heres the story.....I was driving down the road and the truck lost power so I pulled into a body shop and checked it out.I popped the hood and the tube with the foil wrapped around was off so I cleaned it all up and put a new clamp on and I thought I was good to go.Well now my check engine light is on.Any ideas?
Old Apr 11, 2008 | 06:23 PM
clintbonnie's Avatar
clintbonnie
Try and get your fault codes read.. could be a several reasons for the light.. If you live in large city, tell us and maybe someone here on the forum would come to your rescue... I heard of people going on ebay and buying a tuner (like diablo sport or superchip) 2nd hand just for the use of the scanner portion..
Old Apr 11, 2008 | 07:19 PM
madcatter33
yeah I just found a guy who will read the code.Thanks for the reply.
Old Apr 11, 2008 | 07:34 PM
F350-6's Avatar
F350-6
Do you have a chip or tuner on your truck? When you find out what code(s) you have let us know.
It would also be a good idea to check all the other boots (5 more) on your engine to see if any of them are loose. A little trick you may want to try with the tube that came off is to put a little hair spray on the tube before re-installing it back in the boot. It kind of acts like a primer and helps things stay together.
Old Apr 11, 2008 | 07:55 PM
madcatter33
I dont think I have a chip....How can I check to know?
Old Apr 11, 2008 | 08:10 PM
F350-6's Avatar
F350-6
A chip is installed in the PCM. If it was done correctly then you should have gauges to monitor things so you don't damage something.
Old Apr 12, 2008 | 09:31 AM
madcatter33
It is showing codes P1247 and P1248.
Old Apr 12, 2008 | 09:50 AM
zx250's Avatar
zx250
Of the next Riffraff East
Is the light still on. Those codes come from the IC pipe being off, but should have reset after you got her going again.
Old Apr 12, 2008 | 10:08 AM
madcatter33
yeah its still on...any way to manually reset it?
Old Apr 12, 2008 | 10:10 AM
zx250's Avatar
zx250
You should have cleared the codes after you read them. That should reset the light.
Old Apr 12, 2008 | 10:23 AM
madcatter33
Did it again and got them cleared.Good to go now.Also did the foil delete while I had the pipe off.The 6637 filter is next as soon as my existing filter gets some use out of it.Thanks alot.Everyone is alot of help.
Old Apr 12, 2008 | 10:25 AM
zx250's Avatar
zx250
Good deal!
90F250351
Sep 8, 2009 02:07 PM
jase386
Nov 28, 2005 03:32 PM
6T8STANG
1997 - 2003 F150
Mar 23, 2003 07:18 AM
gblakeney
Dec 10, 2001 10:32 PM
rsbeadle
Mar 22, 2001 10:55 AM
