Spark plugs too clean?
Old Apr 27, 2002 | 09:28 AM
TheWiz427's Avatar
TheWiz427
Old May 2, 2002 | 02:05 PM
Sedric's Avatar
Sedric
I recently put in a new set of plugs in my '72 302 at about the same time that I put on a set of headers and switch the point ignition out for a Pertonix unit (kept original coil). After about a week of running I took one of the plugs out and was suprised that it was absolutely clean...looks like new. The porcelain is white and the electrode is light grey.
The old plugs were a light brown colour. I think the new plugs are a hotter plug.
Is this OK or is it a sign that I am running too lean? The water temperature is OK and the truck runs very nicely.
Thanks
Old May 2, 2002 | 04:12 PM
sauerf100s's Avatar
sauerf100s
[updated:LAST EDITED ON 02-May-02 AT 05:15 PM (EST)]Usually white plugs are a sign of running lean. That or the heat range is too high. Between the headers and the Pertronix, you could be having a combo of both. As you probably know, the light brown color is ideal. To get a true reading, you would have to make a wide open throttle run, and then shut down the engine without having it idle. Then check your plugs. Sometimes tough to find a place where you can do this.
Old May 3, 2002 | 08:41 AM
Sedric's Avatar
Sedric
OK, lets say the truck is running lean, would the solution be to put the next size larger main jets in my carb? It has the stock 2 barrel.
Thanks
Old May 9, 2002 | 08:58 AM
phjbbu's Avatar
phjbbu
If it's running nicely and doesn't ping under load, what you've got is a perfect situation. Don't mess with it. You know what happens when you mess with something that's working properly, right?
bryanknie
85
Oct 16, 2022 12:43 AM
truck7575
Aug 2, 2015 09:53 PM
gearheadmb1
New Member Introductions
Jan 25, 2015 06:41 AM
bigcountry62
16
Apr 26, 2013 12:52 AM
autotech
Sep 18, 2000 01:23 PM
