Sponsored by: Real Truck
rear end fluid
Old Apr 12, 2008 | 08:26 PM
Eng1Driver's Avatar
Eng1Driver
Originally Posted by Georger350
so i can just clean it and pour my gear lub in and the friction midafire in at once and go right? i just need to get the clutches to dis engage. hope this helps. plz let me know thankx george
Do you have a problem with your rearend? If your clutches are locked up tight (is that possible?) a simple fluid change may not help.
Also, in case you need it there is a spell check feature located on the top right of the reply board above the smiley's.
Good Luck
Old Apr 13, 2008 | 11:04 PM
biz4two's Avatar
biz4two
Arrow
Hope these links help...step-by-step with pics.
Rear:
Amsoil gear oil
Welcome to guzzle's Rear Differential Maintenance Web Page
Front:
Welcome to guzzle's Front Differential Maintenance Web Page
OBTW: Don't forget to do the front...
biz
Old Apr 13, 2008 | 11:46 PM
CRABBO's Avatar
CRABBO
Rear Gears
thankx for all your help guys, i just went out and bought mobil1 and friction midafirer. now the only question i have is someone told me to take the rear end out and soke the clutches in this friction midafire. what do i do here? i have no idea how to take the rear end out? is it hard to do or am i just wasting my time? please help.
HEY GEORGER DO NOT REMOVE THE REAR END TO SOAK THE FRICTION MODIFIER!! JUST TAKE OFF YOUR REAR PLATE EXAMIN THE REAR HOUSING AND GEARS, TAKE A CLEAN RAG AND WIPE OUT AS MUCH OF THE HOUSING AS YOU CAN,PUT THE REAR PLATE BACK ON WITH SOME BLUE AUTOMOTIVE RTV AND RFILL THE HOUSING TO SPECS.. DON'T FORGET TO PUT THE FRICTION MODIFIER IN FIRST..IF YOU WANT TO YOU CAN INSTALL A MAGNET AT THIS TIME AND DRIL AND TAP FOR A DRAIN PLUG I/4 INCH PIPE PLUG
Old Apr 13, 2008 | 11:56 PM
CRABBO's Avatar
CRABBO
Limited Slip Rear Gears In Heavy Ford Trucks Are Always Under Pressure! If Your Truck "chunks" When You Are Empty And Making A Sharp Turn Remember The Rear Axle Was Set Up To Work Under A Load.. My 99 Crew 6.8 5speed 4.30:1 Still "chunks" When Empty But When I Have My Camper On It It Is Smooth As Can Be
Old Apr 15, 2008 | 09:33 PM
green2000f350's Avatar
green2000f350
The tag on my 2000 F350 4X4 says 75W140 Synthetic only
oldfrt613
Dec 19, 2012 08:56 PM
slk133
20
Jul 14, 2012 03:55 PM
tdrabick
Mar 23, 2007 06:56 PM
GPSMatt
Feb 11, 2006 02:39 AM
TonyG
Apr 5, 2002 06:24 AM
