Sponsored by: Auxito
How much is to much
Old Apr 11, 2008 | 05:52 PM
blacktop06's Avatar
blacktop06
How much is to much
I have a 2003 supercrew.I have a chatter in the rear diff. I did axle seals and outer bearings. When i add my new gear lube I put 8onz of the additive in.I still am geting a chatter now its when the rear diff is cold once it warms up some than it stop. Should i put more additive in? Or will that be to much?
Old Apr 11, 2008 | 06:28 PM
superdutymj's Avatar
superdutymj
It shouldn't take more than specified. If your rearend is still chattering, the damage may already be done and you may need your diff rebuilt.
Old Apr 11, 2008 | 09:11 PM
sclariat's Avatar
sclariat
By chatter, do you mean when cornering?
Old Apr 11, 2008 | 09:30 PM
jimm66's Avatar
jimm66
You might want to do a search, but I heard of having to put in 2 cans of modifier.
Old Apr 11, 2008 | 10:15 PM
BLK94F150's Avatar
BLK94F150
What kind of rear end lube are you using? I'm using Mobil 1 75w90 (I know that it's supposed to be 140) with no additive and I hardly ever get chatter. What I do get, I kind of like as it just means that it's actually gripping back there.
Mike
Old Apr 12, 2008 | 12:47 AM
blacktop06's Avatar
blacktop06
Yes the chattering is around the corners only.I used 75/90 leading edge synth. oil and and a additive.
Old Apr 12, 2008 | 01:00 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Leave it alone...it's fine.
Old Apr 12, 2008 | 05:35 AM
Bobby82490's Avatar
Bobby82490
Thats what i would do, i wish mine still worked like that.
