mercury 390?
Old Apr 12, 2008 | 09:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Bullitt390
That is the head ASSEMBLY number not a real casting number... more than likely it had a C6AE-R casting number
That's the Ford part number for the only cylinder head (as listed in the 1965/72 Ford passenger car parts catalog) used originally on 1966/67 352/390/410/428 engines installed in full sized Mercs, Fords and T-Birds.
So what does it matter what the casting number is? The same head was used on all those engines, so the casting number won't be specific to just one engine size.
In 1968, Ford replaced C6AZ-6049-E with C8AZ-6049-M for use as a service part replacement.
This head was used thru 1971 on cars, trucks thru 1972, so the casting number could be C8AE, D2TE, whatever.
Casting numbers cannot be cross referenced to actual Ford part numbers.
Old Apr 12, 2008 | 09:11 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Then you do not understand how Ford FE cylinder heads work in the REAL world. You will never, ever find the number you listed cast into ANY FE cylinder head i.e. between the 2 middle spark plug holes.
The number you listed (6049) is the part number for a complete cylinder head assembly which means jack in the real world.
Look up a 428 Cobrajet cylinder head and you would get part number C8OZ-6049-F and that means what? Absolutely nothing because the CASTING number is C8AE-6090-J which would come in handy at a swap meet or pricing a rare $100,000 car.
Old Apr 12, 2008 | 09:16 PM
Bullitt390's Avatar
Bullitt390
Here is another REAL world example...
C8WE-6049-A is the part number...
what does the real world show?
Old Apr 12, 2008 | 09:44 PM
NumberDummy
C8WE is the casting number for this head, not the part number.
This is a different head than the one installed in 1966/67 full sized Fords/Merc's and Birds.
C8WE - E = engineering.
Ford part number prefixes end in Z, specific L/M part number prefixes end in Y.
It could be one of three heads used in 1968/72 depending upon application. *
C8OZ-6049-A: 1968 Fairlane/Torino/Montego 2V with 3 or 4 speed. 1968 Torino/Montego GT; Mustang/Cougar with 3 or 4 speeds or C6. All: use with T/E.
C8OZ-6049-B: 1968 Torino/Montego GT; 1968 Mustang/Cougar. All: use without T/E.
C8OZ-6049-J: 1969 Torino GT/Montego GT; 1969 Mustang/Cougar 4V, Use with IMCO.
* Both C8OZ-A & B replaced earlier heads for use as service part replacements.
T/E - Thermactor Emission - smog pump.
EDIT: It might even be: C80Z-6049-K, used for all HiPo (off road) vehicles - 1968/71 - use with T/E.
While this head carries a 1968 part number, here again the catalog sez: use as a service part replacement for 1965/67.
Old Apr 12, 2008 | 10:52 PM
crescentwrencher's Avatar
crescentwrencher
i remember the block being c5ae and the heads being c4ae. which doesnt make sence since the valve cover on the drver sidee has the oil fill hole and the other has the pcv valve
Old Apr 13, 2008 | 09:47 AM
Bullitt390's Avatar
Bullitt390
I am not implying the heads I pictured are or were installed on 410 Mercury engines, merely showing the PART numbers you posted have nothing to do with what one would find in the real world, i.e. CASTING numbers...
So a C6AZ-6049-E translates into a C6AE-R Casting number and means therefore nothing because it was the common FE head from 66-68
Old Apr 13, 2008 | 12:05 PM
Mil1ion's Avatar
Mil1ion
Bill and I had this part number vs casting number discussion a couple of week ago.
Old Apr 13, 2008 | 12:35 PM
Bullitt390's Avatar
Bullitt390
Really? What thread?
Old Apr 13, 2008 | 01:23 PM
Mil1ion's Avatar
Mil1ion
https://www.ford-trucks.com/forums/7...-of-390-a.html
Old Apr 13, 2008 | 03:26 PM
crescentwrencher
there she is, even got those rare pent roof valve covers with the lightning strikes on em
kelwar
19
May 24, 2021 05:50 PM
Chaosracing
Feb 11, 2015 04:43 PM
VaFordman26
22
Mar 19, 2013 08:01 PM
65f100CoryE.
50
Oct 10, 2008 08:02 AM
chissler
Jun 11, 2003 05:19 PM
