Code Help - Any ideas??
Old Apr 10, 2008 | 10:21 AM
UMDSmith's Avatar
UMDSmith
Thanks Pawpaw, I didn't realize 224 was TPS, that I'm familiar with (damn mustang ). I have actually changed it once on the ranger. I had to do the entire unit because ford decides to use stupid phillip screws.
Can the tps cause the symptoms described though? I didn't think it could control timing and spark to the level I am having the problem.
When you say PO224, what does the PO stand for.
As far as the cat, I'm going to end up removing it from the system (gutting it to start so that it isn't causing any pressure issues). I don't have any emissions where I live, so don't have to worry too much about that.
Old Apr 10, 2008 | 11:39 AM
pawpaw's Avatar
pawpaw
Well P= Power Train, for OBD-2 diagnostics, B=Body, C=Chassis, U= Network, for the newer CAN (Contoller Area Network) equipped vehicles.
The OBD-1 three digit codes didn't have the P in front of the digits.
Well lets think about the TPS code for a minute, suppose the TPS were telling the computer that the throttle was at the wide open position!!!!
What do you suppose the computer would think it was supposed to do about fuel delivery????
Quickly have the injectors dump more fuel into the cylinders, RIGHT, so if in fact the computer is doing what it's been told to do, dump more fuel when the TPS says the throttle is open, but if it's getting a false signal from the TPS when the throttle is really closed, then the air/fuel mixture could go mighty rich!!!!
So address the TPS code, reset the computer, so it knows a repair has been made, restart the vehicle, warm it up & re-do your KOER codes & see if the repair has cleared the code & note how the engine is running.
If it's been running rich for a long time, the plugs could be carbon fouled, so consider that in your evaluation.
If it's still running poorly, then do the fuel pressure check & vacuum meter check for a obstructed exhaust test & seeing as how it really acts up after warming up some, so the O2 sensors are coming online, also do a O2 sensor test & post the results. WHEW!!!! lol
Old Apr 10, 2008 | 11:49 AM
UMDSmith's Avatar
UMDSmith
Will do. The plugs and wires are new, as I started with what I could change first, thinking maybe it was a spark issue.
SBChero
15
Jan 18, 2014 10:21 AM
79f150
23
Aug 15, 2013 10:28 AM
BRay09
15
Mar 5, 2011 02:44 PM
ErickSaint
Oct 28, 2006 11:08 AM
tmcm
17
Dec 21, 2005 07:01 PM
