oil in coolant tank
Hi stang3O2,
Interesting! You do mean engine coolant recovery tank right?
Seems to me that when the coolant moves in & out of the tank due to it getting hot then cold>then it draws the coolant in, there would be signs of it elsewere too.
There is also an outside chance that when the coolant was changed last, & if a funnel was used & it had not been cleaned throughly, that would be another probable cause & your just noticing it now.
Is it a lot or just covering the coolant tank inner walls?
I noticed the coolant overflow tank had oil in it after driving today. There was no signs of coolant on the dipstick or oil cap.
mfletcher1969
07-21-2012 01:37 AM
