F250 vs F350
on
1 Post
Like everyone said if you get a SRW 350 it has slightly more capacity and slightly higher then a 250. Other then that just the badging is different, like Jeff stated you definatly want to go with a Lariat and they are a fairly common truck. I never rely on the lie o meter I just use it as a compass and a thermoter. Good luck finding a 350 SRW they are definatly a rarer breed.
The only difference is the extra rear leaf spring. The higher towing capacity is because the rear springs will now support more tongue weight. MPG will be no different. I don't know about particular state laws, but here in the Greatest State of Texas, the tags will be a tad higher due to the extra 500 pounds gross weight capacity.
The interesting thing is that a dually actually is rated to tow LESS than a SRW due entirely to the added weight of the rear axel and extra set of tires. Ain't that a hoot.
[quote=joegebff;601753. I don't know about particular state laws, but here in the Greatest State of Texas, the tags will be a tad higher due to the extra 500 pounds gross weight capacity.[/quote]
do they make you get weighted tags rated at the GVWR. i have mine registerd for 20K pounds. but when my dad bought his '05 King Ranch F350SRW, they issued him tags for 7500 lbs. i told him to take that crap back to the dealer who charged him for the tags and ask how did they figure 7500 lbs would work on a truck with a GVWR of 11400 and GCWR of 20000?
on
1 Post
The only difference that i know of is the springs and the block but the latter doesn't matter much .
Here is what you need 2 kno.
There is a two-character spring code on the vehicle certification sticker on the lower doorpost behind the driver's door. The first character is the front spring code, and the second character is the rear spring code. A common spring code for a CrewCab 4x4 would be VB. The V means 5,200 pounds front springs, and the B usually means the rear springs on an F-350 SRW. However, some F-250s also have code B rear springs.
Any pickup can have any available front spring code - depending on options, and it doesn't matter whether F-250, F-350 SRW or F-350 DRW. Here are the spring codes for the front leaf springs on '99 thru '04 PSD 4x4 pickups:
T = 4,400 pounds @ground
U = 4,800
V = 5,200
W = 5,600 (rare on a pickup)
X = 6,000 (only with snow-plow pkg on a pickup)
Rear spring codes:
A = F-250 & Excursion (6,084 pounds @ground)
B = F-350 SRW (6,830 pounds @ground)
C = F-350 DRW (8,250 pounds @ground)
If you already have code B rear springs, then you already have the same rear springs that are on F-350 SRWs.
U = 4,800
V = 5,200
Rear spring codes:
Stephen67
51
01-30-2012 10:14 AM
couchsachraga
03-10-2011 08:12 PM
