eng. missing under coast condition?
Old Apr 9, 2008 | 03:04 AM
jhnlennon's Avatar
jhnlennon
i have yet another question regarding my 85 dually i picked up. it seems that when you are doing about 55 or so and let off the fuel i am getting what appears to be a bad engine miss. any ideas?
Old Apr 9, 2008 | 06:38 AM
PLC7.3's Avatar
PLC7.3
Has the truck ever stalled at a light when the clutch is pushed in........
Old Apr 9, 2008 | 06:39 AM
mistakenID's Avatar
mistakenID
Is the truck vibrating when you coast? I would look more to loose U joints causing a vibration than an engine miss.
Need more information!
Old Apr 9, 2008 | 08:59 AM
jhnlennon's Avatar
jhnlennon
no it hasnt stalled out on me at idle, and i am pretty sure it is the motor missing because it does it sparadically. the whole truck bucks pretty bad when it does it. when you give it fuel again after it starts doing it,it goes away
Old Apr 9, 2008 | 01:16 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Going back to basics.. When was the last fuel filter change? have you changed the fuel return lines between the injectors? Wondering if some air is getting in when you let off on the power band. I also found on my 93 a bad fuel line from the tank along the frame. gave me real fits to find it. It ran rough like yours.
Old Apr 9, 2008 | 03:42 PM
David85's Avatar
David85
Any smoke happening during those conditions?
Old Apr 9, 2008 | 03:55 PM
jhnlennon's Avatar
jhnlennon
i havent really noticed to much smoke, it does smoke a little whe you get on the throttle. the fuel filter looks new, i havent noticed the injector caps leaking any fuel but that doest mean they arent leaking fuel i guess. it doest have any cold start issues.
Old Apr 9, 2008 | 06:21 PM
David85's Avatar
David85
One more question, does the truck try to stall if you rev the engine up to 1500-2000 RPM and then release the accelerator (at standstill in neutral)?
Old Apr 9, 2008 | 07:36 PM
jhnlennon's Avatar
jhnlennon
no it doesnt.
Old Apr 9, 2008 | 09:27 PM
PLC7.3's Avatar
PLC7.3
How old is the IP.........and injectors.
Old Apr 9, 2008 | 09:57 PM
jhnlennon's Avatar
jhnlennon
Originally Posted by PLC7.3
How old it the IP.........and injectors.
thats a good question. they do look pretty old.
Old Apr 9, 2008 | 10:10 PM
David85's Avatar
David85
This is one I haven't heard before. A misfire should cause a smoke puff that lines up with the thump in the engine (or at least SHOULD). I would check the drive shaft just to be sure. A loose U joint can cause some strange symptoms (tranny in neutral).
Old Apr 9, 2008 | 10:26 PM
George D.'s Avatar
George D.
Sounds like a bad ring in pinion to me. One of the teeth may be damaged on the back side when you let off the go pedal the oposit side of the ring and pinion ride on each other the bucking may be the bad tooth comming around.
Old Apr 9, 2008 | 10:40 PM
George D.'s Avatar
George D.
Actualy it may be in the trans since its only in 4th. on the decel side of the gears.
Old Apr 9, 2008 | 10:46 PM
jhnlennon's Avatar
jhnlennon
a chipped tooth in the ring and pinion would almost definately make some gear noise wouldnt it? a loose u joint would result in drive train clunk wouldnt it? i am getting neither of these. i am pretty sure it is the motor missing. its acting just like a gasser does when it is loading up with fuel. the truck is bucking pretty bad, and it doesnt make any clunking noise when it does it, which is sparadic.
