Truck does something weird- sometimes...
Old Apr 8, 2008 | 04:01 PM
scottie2hottie's Avatar
scottie2hottie
There were no burned pins on any of them but on of the harnesses had the clip broken off, not something i did, im assuming that means the gasket has been replaced once before. i cleaned them all up a bit and plugged them all back in, hopefully(probably being too optimistic) they'll settle down. Any other ideas? how likely is this IDM? it's been doing this a couple months but the trucks doesn't run too awful much. it's very sporatic when and if it occurs.
Old Apr 8, 2008 | 05:06 PM
tjbeggs's Avatar
tjbeggs
Did you do the test in the link I gave? if not you need to. That will show problems inside the valve cover
Old Apr 8, 2008 | 09:24 PM
scottie2hottie
i tried to let it idle a lot today. I probably put 2 hours on it tonight with ample idle time. No occurance. It did do it once earlier today before I tore everything apart.
RedDevil460
Aug 12, 2016 06:07 AM
Bill Carpenter
1983 - 2012 Ranger & B-Series
Mar 27, 2013 12:58 PM
Brandon Harrison
Dec 2, 2012 01:07 PM
QHgirl
1997 - 2003 F150
Mar 29, 2011 03:35 PM
jedijeb
Jul 16, 2010 12:19 PM
