Aerostar Ford Aerostar
Crankcase ventilation system
Old Apr 7, 2008 | 10:33 AM
VanGo's Avatar
VanGo
Anyone have the scoop on these? They differ from a standard PCV system but I'm not sure how exactly. The claimed benefits are reduced crankcase pressure yielding better ring seal and fewer oil leaks caused by pressure.
Google it. I thought it might cure my leaks and give a little better efficiency. Moroso and Mr Gasket sell them
Old Apr 7, 2008 | 05:40 PM
93nighthawk's Avatar
93nighthawk
I'm not quite sure what you are talking about Justin?
The reason for a PCV (Positive Crankcase Venitlation) system is to prevent pressure build up and the things that you listed. The valve does wear out over time and needs replaced.
I am not to sure how they could improve on that?
Old Apr 7, 2008 | 08:02 PM
VanGo's Avatar
VanGo
Instead of reducing crankcase pressure using a PCV system that routes vapors and contaminants back into the intake, an evacuation system draws exhaust gases using the Bernoulli principle to provide the vacuum necessary as they exit. More reliable , better fuel mixture, cleaner oil albeit it harder on the environment.
Check out the section on Exhaust slashcut evacuation here:
Honda-Tech.com: Forced Induction: The Official Crankcase Evacuation thread for Turbo Hondas / PCV / Catchcan /
Here's how the installation looks:
Emissions and Crankcase Ventilation - Exhasut Scavenging
Old Apr 7, 2008 | 09:43 PM
xlt4wd90's Avatar
xlt4wd90
It all comes down to the condition of your engine. If the rings are still sealing properly, there should be minmal blow-by, and the stock system should work fine. If there is a lot of blow-by, the stock system would chum up the intake manifold in short order. If you use the exahust system to scavenge it, it can hurt the catalytic covnerter. You can use the catch-can setup to catch the sludge. But it all means that your engine is on its way out, and probably needs new rings at the least.
You want PCV to prevent pressure build up in the crank case, which can blow oil seals. I guess it's possible to get a little more power if you applied some vacuum to the crank case, but I doubt you will see 2-5% as the guy claims.
Old Apr 8, 2008 | 06:58 AM
VanGo's Avatar
VanGo
I think it mainly applies to race engines with looser tolerances. Interesting idea though. I can see where one would want a purer air/fuel mixture for performance.
Twilight Fenrir
Nov 5, 2013 05:21 AM
Ryan85
Jun 12, 2011 02:07 PM
eallanboggs
1997 - 2003 F150
Jan 23, 2010 11:29 PM
aaronwilliams83
Oct 22, 2006 07:09 PM
sixx pak
Jan 31, 2003 02:18 PM
