Sponsored by: Real Truck
AXLE ID NEEDEd
Old Apr 7, 2008 | 01:07 PM
miker67's Avatar
miker67
I missed where you already took it apart. If you haven't pulled the yoke off yet, you may be able to gingerly try and get this measurement. In the meantime, I will look and see if i can find the OEM specs.
Old Apr 7, 2008 | 01:09 PM
BENG0924's Avatar
BENG0924
ok good but I already pulled the pinion nut and have no idea how much resistance to put back on
Old Apr 7, 2008 | 01:11 PM
BENG0924's Avatar
BENG0924
i was replying while u were thanks alot for ur help tho how do i get this measurement with the nut off? Maybe i dont understand how the measurement is taken i thought it was via turning the nut
Old Apr 7, 2008 | 01:19 PM
miker67's Avatar
miker67
Yes, you are turning the nut, but you have to have the axle off the ground so the tires are not touching the ground anymore. You are simulating the input power of the driveshaft. There is a certain amount of preload, or deliberate pressure on the pinion bearing, the resistance of which can be measured. By turning the nut, all you want to do is rotate the whole axle assembly, measuring how much force it takes to turn it. There are two different measurements on the pinion nut. One, is the force applied to crush the crush sleeve, and this is in the hundreds of foot pounds(this is measured with the yoke blocked so it can't rotate. The second, is the force required to rotate the yoke after the nut has been run down and the crush sleeve crushed This measurement is typically only a matter of a few inch pounds. As described earlier, this is done with the axle assembly free to rotate.
Old Apr 7, 2008 | 01:21 PM
F350-6's Avatar
F350-6
It looks like my attachment got cut short. I meant to include more info. I'll add these. After a quick review it looks like 20 in lbs. is what you're looking for. Hopefully miker67 can confirm this
File Type: pdf
File Type: pdf
Old Apr 7, 2008 | 01:35 PM
BENG0924's Avatar
BENG0924
Ok but I do not need to go thru all of those steps if i want to replace only the seal correct, just confirming thanks for the info
Old Apr 7, 2008 | 01:45 PM
F350-6's Avatar
F350-6
No that was just some additional info I meant to include earlier so you had a better feel for what you were looking at.
Old Apr 7, 2008 | 01:51 PM
BENG0924's Avatar
BENG0924
10 4 thanks alot guys if u have any more input love to hear it otherwise I will try to get to project tonight and update tomm
Old Apr 7, 2008 | 02:40 PM
miker67's Avatar
miker67
20 inch pounds sounds correct. That was the number I had in my head, but I didn't want to say without verifying it. The first PDF file has all the steps you should need, but I would suggest you read the other two carefully as well. It will help give you an understanding of how the differential is assembled, so that the whole preload/rotational torque concept makes more sense.
Old Apr 7, 2008 | 09:32 PM
aldridgec's Avatar
aldridgec
Yeah, but 20 in-lbs is with just the pinion installed, and doesn't take into account the preload on the carrier bearings and drag from anything else installed. Unfortunately it is critical to take the measurement before hand. However, it takes a HUGE amount of torque to crush the sleeve altering the preload. In these cases, torquing the poinion nut down to 50 to 75 lb-ft is adequeate and won't mess the preload. You can also check it because it should remove all of the lateral lash from the pinion.
Old Apr 8, 2008 | 08:05 AM
BENG0924's Avatar
BENG0924
so u r saying I should torque it to somewhere between 50 and 75 lbs?
Farmtruckn
Aug 2, 2015 12:30 PM
Wrktrk
Apr 12, 2015 11:04 AM
BKelley7.3L
Jul 2, 2014 11:43 AM
driveguy
Mar 14, 2012 09:30 AM
