16.5" Rims
Old Apr 6, 2008 | 07:47 AM
77F250Custom4spd's Avatar
77F250Custom4spd
16.5" Rims
Does anyone know where I can get stock 16.5 inch rims for a 1977 F250 4x4?
Old Apr 6, 2008 | 08:26 AM
brh1969's Avatar
brh1969
Can i make a suggestion?If youre getting new wheels anyway,why not get 16".Tires are cheaper,easier to find,bigger selection etc.16.5 stuff is getting hard to find and expensive,in my part of the country anyway.I got my 16" stock wheels from my local tire shop brand new for like 25$ each.
Old Apr 6, 2008 | 08:41 AM
78f250_rls's Avatar
78f250_rls
Becarefull if you do go with 16" rims, they will not fit some for the trucks due to the brakes without alittle grinding. I am thinking of going 17" to get away from the 16.5s, but have to look into it alittle more.
Old Apr 6, 2008 | 12:35 PM
rbaker6336's Avatar
rbaker6336
some of the 16.5 wheels won't clear the caliper either
Old Apr 6, 2008 | 03:58 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Where are you located? I have a set of stock 16.5 wheels in great shape that ill let go cheap.
Old Apr 6, 2008 | 08:10 PM
77F250Custom4spd
Im near Madison WI
I want to get new ones cause im hoping theyll have that little ridge that keeps the bead of the tire from unseating itself and coming off when the tire goes flat.
Old Apr 6, 2008 | 08:35 PM
stealth1's Avatar
stealth1
17" would be your best bet as stated more tire options. If you really want I have a couple in decent shape.
Old Apr 7, 2008 | 01:12 PM
ChaseTruck754's Avatar
ChaseTruck754
Originally Posted by 77F250Custom4spd
Im near Madison WI
All 16.5's are built that way - they don't have the internal bead. Go to either a 16" or 17" rim depending on what will fit your (calipers - as mentioned) truck and budget...
