Distributor with no advance?
Old Apr 6, 2008 | 06:35 AM
tommyleea's Avatar
tommyleea
1966 F100 with a 240 engine. I was checking my timing the other day, and disconnected the vacuum line to the distributor. I increased the RPM to 3000, and the timing didn't advance. Reconnected the vacuum line, and advance was working. I assumed the weights were frozen for the mechanical advance. So, I removed the distributor, and to my surprise, there are no weights for the mechanical advance! I guess I have never seen this before. Does this distributor not have mechanical advance?
Tommy
Old Apr 6, 2008 | 06:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Tommy
No weights = you have the Ford "Loadomatic" distributor used on some 240 engines 1965/72.
Old Apr 6, 2008 | 06:59 AM
tommyleea's Avatar
tommyleea
Thanks, I guess that means there won't be any advance without the vacuum line connected?
Old Apr 7, 2008 | 09:50 AM
airharley's Avatar
airharley
100% correct.
Old Apr 7, 2008 | 09:14 PM
tommyleea's Avatar
tommyleea
Originally Posted by airharley
100% correct.
Thanks. That is a new one on me.
Tommy
Old Apr 7, 2008 | 09:39 PM
itsmywifestruck's Avatar
itsmywifestruck
Just throwing this out there...wouldn't he get better performance from the truck if he swapped out with a 300 distributor? I know they talk about it on a 223, with some other mods to make it work, but it oughta drop in a 240 i would think.
ROb
Old Apr 8, 2008 | 08:57 AM
tommyleea's Avatar
tommyleea
ROb
You are probably correct Rob, but I just use it to putz around in. Maybe some day I will go thru it and make some changes for performance and comfort. Cheers.
Tommy
bigwalt1
20
Jun 18, 2010 08:11 PM
M6EV139445
Dec 4, 2006 04:52 PM
Unimog005
General Automotive Discussion
Feb 25, 2005 11:23 AM
351 power
Electrical Systems/Wiring
Sep 16, 2003 06:17 AM
rodr
Sep 14, 1999 04:05 PM
