Timing Jumping
Old Sep 13, 1999 | 10:45 AM
rodr's Avatar
rodr
Timing Jumping
I was trying to set my timing yesterday, I have all the vacuum lines disconnected and plugged.
I set it to 14B and it started to idle nicely, but then the engine speed dropped and I saw the timing
jump at the same time about 8deg, then go back to
where I set it. This repeats itself until the engine will die. Also noticed that when the engined is revved, there is no mechanical advance at all.
Can there be something wrong with the distibutor's
mechanical advance? Does it have one? Its a '73 460 with a stock distributor out of a Lincoln.
Thanks for any help,
Rod
Old Sep 13, 1999 | 11:35 AM
Phillip Guidry's Avatar
Phillip Guidry
Timing Jumping
1973!The last year of points!Those were the days.With the points properly gapped,a good cap, rotor,wires,plugs and coil,the engine should idle steady enough to adjust timing to several settings and not die unless you go overboard.The up & down variations in timing you saw could be from the RPM flucuation of a poorly running engine,or,from a coil or wire that is giving up.I agree you should see advancement when you accelerate,so, the mechanical advance must be stuck closed or open.Remove the cap and try twisting the rotor.It should rotate under spring tension and pop back by itself.If not,i believe you can remove the plate the points are attached to for further inspection.And while you are in there,inspect the breaker plate for wear and check the ground strap to the dist. body.
Phillip
Old Sep 13, 1999 | 12:23 PM
rodr's Avatar
rodr
Timing Jumping
Thanks Phillip
Down the road, I'll probably install one of those MSD setups I keep reading about, but for now I need to stay under my Wife's budget radar!
I'll take it out and apart tonite, to see whats what.
Rod
Old Sep 13, 1999 | 04:04 PM
ray's Avatar
ray
Timing Jumping
check mechanical advance.
Old Sep 14, 1999 | 08:56 AM
rodr's Avatar
rodr
Timing Jumping
I took the distributor apart and the mechanical advance looked OK. I then cleaned up everything I could get to, roughed up any possible grounding surfaces and installed the points and condensor from the 360.
Boom, fired right up! Fast idle was smooth, regular idle was smooth, was able to set the timing correctly and set the idle to 650.
Don't know which thing did it, but I'm happy!
Of course the old beast couldn't totally bless me: I see that I have oil leaks at the rear of the manifold (again!), but thats another post ;-(
Rod
Old Sep 14, 1999 | 04:05 PM
D. Bellis
Guest
Posts: n/a
Timing Jumping
bb429power
Dec 9, 2012 11:29 PM
Dan92668
1983 - 2012 Ranger & B-Series
Feb 29, 2012 01:13 PM
neb0244
18
Sep 2, 2010 04:06 PM
hammerin16ds
Modular V8 (4.6L, 5.4L)
Nov 26, 2007 06:29 PM
mshumack
Sep 19, 2002 02:44 AM
