flathead 8, whats this?
Old Apr 6, 2008 | 03:31 PM
cts1954's Avatar
cts1954
I think that is the same, part number 9400 is the push rod, one piece but it doesn't show the different diameters. Mine just drops down into a tight fit hole to ride on the cam.
Old Apr 6, 2008 | 11:37 PM
jmadsen's Avatar
jmadsen
Hey, thanks everyone for all the responses.
cst 1954 that sure looks like it, although this larger diameter part measures about 2 &1/16 inches long. The larger end has a concave shape to it (warn looking) the smaller diameter end looks like it could have had a notch ground in it and then it looks like it could have been broken off ? kind of wierd anyway. I think they had the original style fuel pump on it?
thanks
Old Apr 7, 2008 | 07:09 AM
cts1954's Avatar
cts1954
It is always nice to know where the loode parts go, the warn ares is where it was riding on the cam, mine is like that too. I am sure the rods were all made somewhat different as far as the dimentions. In any case you need a new one.
Old Apr 9, 2008 | 03:19 PM
jmadsen's Avatar
jmadsen
One and a third fuel pump rods??
so I pulled the fuel pump off it has the 10 inch long push rod part, #9400 from diagram and its the same diameter the entire ten inches. so if that broken peice is an old pushrod that broke off how did it get into the crankcase?
I couldnt believe how much oil-tar chunks etc were inside the block once I pulled off the intake manifold, the inside walls of the block have at least 3/8 + inches of buildup.
I kind of want to clean it up a bit before final dissasembly just to make it easier to work in and not having so much crud to deal with. What would you recommend? lots of degreaser and power washer or high pressure car wash?
thanks
Josh
Old Apr 9, 2008 | 05:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If it's an old pushrod, you've got MAJOR problems!!!
Scraping with rags stuck in the drain holes, or a shop vac to suck up pieces, is the way to go
Old Apr 15, 2008 | 10:11 PM
effie_man's Avatar
effie_man
Originally Posted by havi
Frank Oddo's "Ford Flathead V8 Builder's Handbook 1932-1953
A book recommended by mtflat (IIRC)
Jmadsen, I'd go look at my 8BA right now, but the weather is winning the battle.
I have that book too, Its awesome. I believe that is the fuel pump push rod too
Old Apr 15, 2008 | 10:13 PM
effie_man's Avatar
effie_man
thanks
Josh
just wait till you look in the oil filter canister
jmadsen
29
Jan 15, 2017 06:39 PM
jmadsen
Aug 3, 2008 08:18 PM
jmadsen
Jul 20, 2008 10:00 AM
jmadsen
May 18, 2008 09:09 PM
jmadsen
Apr 25, 2008 06:17 AM
