bought another 53 8RT flathead
Old Jul 19, 2008 | 11:19 PM
jmadsen's Avatar
jmadsen
Well I did go and look on Friday-and purchased it, I forgot to grab the Compression testor etc(Dang it), so I couldn't check it. it ran really good as far as I could tell? It has a metal (assuming a rebuild tag) on the lower passenger side front just above the oil pan. it has some numbers stamped in it but not sure what they mean (92249). I couldn't make out the other data on the plate, looked like a name of rebuilder??? pretty greasy though. the odometer said 39000 but was not working so who knows.
the water pumps appear to be correct for my 51 so maybe they have been replaced at some point, do those look like the correct pumps for a 51?
http://i216.photobucket.com/albums/c...head8RT020.jpg
http://i216.photobucket.com/albums/c...head8RT016.jpg
http://i216.photobucket.com/albums/c...head8RT004.jpg
Oh: also I couldn't figure out why they would grind the 8RT off the heads but they did!!! after I cleaned it a little better I could see where they had ground them off then repainted, seems really odd?? I also got a 4 speed trans with it from a different truck.
I'm planning on putting this in my truck for now and working on getting it back on the road, then see about rebuilding the other flathead,??
Josh
Old Jul 20, 2008 | 07:27 AM
petey shoes's Avatar
petey shoes
josh, they look to be the same as pumps on my rt, although the pan is backwards from mine. probably just the application? tag is from rebuilder, but have only guesses as to grinding heads
Old Jul 20, 2008 | 07:36 AM
havi's Avatar
havi
I'll have the Roast Duck
Craigslist has this one by me....I wish I had $300 to spare right now. 1948 Ford flathead V8 - 8RT
Old Jul 20, 2008 | 07:54 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Hmmmmm... He "put oil in it and primed it through the distributor shaft and it definitely made oil pressure".... Oh-Kay.... I'd sure like to know how he did that!
Old Jul 20, 2008 | 10:00 AM
jmadsen's Avatar
jmadsen
ya that doesn't look to bad, the rebuild data plate looks pretty detailed too, I dont think I will ever know the specs without disasembling mine!
Ive heard of priming through the dist shaft of other engines- but didn't know you would get a pressure reading???
jmadsen
Ford Truck Parts for Sale
37
Sep 19, 2017 11:01 PM
jmadsen
29
Jan 15, 2017 06:39 PM
jmadsen
Jan 13, 2017 10:39 AM
jmadsen
Mar 6, 2011 12:58 AM
jmadsen
Sep 20, 2010 07:48 PM
