ignition timing on 302
Old Jul 18, 2002 | 04:19 PM
Sedric's Avatar
Sedric
The manual for my '72 302 calls for the timing to be set at 6 degrees BTDC (I assume with the vaccum hoses disconnected from the distributor). If I set it that way and reconnect the vaccum hoses the timing is then retarded about 10 degrees and it idles real slow. Is that how it is supposed to work? I have the type of dist. with the 2 vaccum connections. Do I have the hoses connected to the right ports?
If I open up the throttle the vaccum goes down and the timing is advanced.
How should I go about setting the timing on this beast?
Thanks for help in advance.
Old Jul 18, 2002 | 04:46 PM
thatdude's Avatar
thatdude
[updated:LAST EDITED ON 18-Jul-02 AT 05:50 PM (EST)]In the past I have always done away with the rear hose and have the front hose running to ported vacuum (vac when the throttle opens).
Then I just set the timing as directed.
ps, I also unscrewed the front bolt from the dist and removed the washer in front of the spring. (timing advances a little quicker).
This is what I have done....I would suggest a second opinion. Sometimes I'm an idiot.
Old Jul 18, 2002 | 09:52 PM
TorqueKing's Avatar
TorqueKing
80ford100
Feb 3, 2015 09:13 PM
waystro
Apr 1, 2013 08:55 AM
tatonka
Feb 9, 2005 03:02 PM
stgdive
Mar 19, 2004 05:19 PM
roush6
13
Apr 25, 2001 07:35 PM
