Sponsored by: Auxito
Misfire on #7 AGAIN
Old Apr 5, 2008 | 05:31 PM
JOE-M's Avatar
JOE-M
Misfire on #7 AGAIN
My son's truck. 1997 F150 XLT 5.4 Auto. This is a problem that keeps rearing it's ugly head. About a month and a half ago the truck started to run extremely rough. Pulled the codes with Auto Enginuity and it said #7 misfire. Cleared the codes and test drove it. Ran fine for about 3 miles and then it started doing it again. Pulled the codes again, same thing so we replaced the #7 COP and all 8 new plugs. The truck ran fine for a week and then it started it again. Pulled the codes, it was #5 this time. Bought another one and replaced #5. Fast forward 1 month. It started running rough again, scanned code for #7 misfire. Cleared the codes and it runs fine. Took it on a 30 minute drive and everything is fine.
The question is, what causes it to start running rough and set this code and then why does it go away when I reset it. Nothing else done to it, just reset the codes. It has to be something that is causing the cylinder to start misfiring other than the COP failing. Wiring to the COP maybe? And then how does clearing the code make it clear up and start running right?
HELP. This is his daily driver for work and he's getting fed up with it crapping out on him.
Joe
Old Apr 6, 2008 | 01:31 PM
JOE-M's Avatar
JOE-M
Here's an update. From a cold start today it reset the ses light within 15 minutes. If you read the codes and erase them the truck will run fine.
Anybody have any ideas on this? Joe
Old Apr 6, 2008 | 07:34 PM
steve(ill)'s Avatar
steve(ill)
erasing the code does not make the truck run better. if you have an oops or upset, you get a code recorder that tells you what it was. it may go away on its own, it may be intermittant. the light just tells you a code has been recorded. what type plugs did you use? the 5.4 seems to like Motocraft better than others.
Old Apr 6, 2008 | 10:14 PM
LxMan1's Avatar
LxMan1
Check for moisture in the boot. Did you use dielectric grease on the boots?
Old Apr 7, 2008 | 05:18 AM
JOE-M's Avatar
JOE-M
The truck will be back at my house tonight so I'll work on it again when I get home from work. I don't remember which brand of plugs they were but I'll look tonight. They were platinum but weren't Motorcraft, that much I know. I did use dielectric grease on the boot but maybe I didn't use enough. I'll pull the COP tonight and check on the moisture.
Thanks for the help, Joe
Old Apr 10, 2008 | 08:20 PM
JOE-M's Avatar
JOE-M
OK, here's the latest. Pulled #7 COP and the hole had water in it. I have no clue where it came from. Dried the COP off and the water out of the hole, re-greased and swapped #7 and #6 around and reinstalled them. Same thing happened again. Drove for a mile and it started again #7 misfire. Saturday we'll buy a new Motorcraft plug and replace the #7 plug (Bosch platinum in there now). Does anyone have any other suggestions on what to do or how to test this problem.
Joe
Old Apr 11, 2008 | 07:28 PM
40LUTZAG's Avatar
40LUTZAG
I had a similar problem. Is there a k&n if too much oil gets on it and in the mass air flow sensor. your computer can go haywire.
Old Apr 11, 2008 | 07:56 PM
JOE-M's Avatar
JOE-M
No. No K&N, straight factory paper filter. Maybe it's the mass air flow anyway. Any clues how to test it?
Thanks for your help, Joe
Old Apr 11, 2008 | 08:09 PM
95 turbo diesel's Avatar
95 turbo diesel
I had the same promblem on my sisters 97 F150 5.4 ,it was the heater hose dripping coolant on the #7 coil.
Old Apr 11, 2008 | 09:16 PM
JOE-M's Avatar
JOE-M
We'll check that tomorrow when we change the #7 plug over to a Motorcraft.
Thanks, Joe
Old Apr 12, 2008 | 02:58 PM
JOE-M's Avatar
JOE-M
Here is the end to the story (I HOPE). Pulled#7 COP to replace the plug with a Motorcraft brand (we wound up having to go to Ford $11 for 1 plug). The hole still had a little water down in it. Blew it out and then vacuumed it out. Changed the plug and so far it's gone 15 miles without messing up. Maybe it's fixed, we'll know next time it rains. Still can't figure out where the water comes from.
Thanks so much for y'alls help, Joe
Old May 21, 2008 | 03:26 PM
swright_47's Avatar
swright_47
Like turbo said, check the heater hose for leaks just above # 7
Old Apr 21, 2020 | 11:43 PM
Gregory Evans's Avatar
Gregory Evans
Water in plug
I had a similar problem on my 97 F150. I finally found that water was leaking in around the windshield washer nozzles that are located on the hood. I put some clear silicone around the base of the nozzles and problem solved.
Old May 3, 2020 | 09:27 AM
newfordy's Avatar
newfordy
Yeah, I remember the 5.4s had a problem with water leaking down into the #7 causing misfire. Can't remember a specific source.
Old May 26, 2020 | 05:26 PM
John Padgett's Avatar
John Padgett
rig up a hose onto your shop vac
3/4 od 1/2 id
i use it a lot
never tried ATV
