More Help
Old Apr 5, 2008 | 05:28 PM
reifwj's Avatar
reifwj
More Help
I still have not pulled the motor back out and now i have a puddle of transmission fluid under the trany. Here is the link to the original problem.
https://www.ford-trucks.com/forums/7...ml#post5992231
Did i mess up my torque converter?
Old Apr 5, 2008 | 09:52 PM
Freightrain's Avatar
Freightrain
You shouldn't have, unless you punchered it somehow? The only thing would be the seal in the front of the pump(that convertor slips into), might be damaged?
Can you spin the torque convertor now? It should be basically loose under there with no bolts in it. Usually with it pushed all the way into tranny, it should be maybe 1/4" away from flexplate.
Is it leaking around the dipstick tube?
Fomoko1
33
Jul 24, 2024 11:30 PM
rangermike
Jul 20, 2012 09:56 AM
customfer1973
Jun 1, 2011 07:56 AM
wreedZ71
2004 - 2008 F150
15
May 14, 2009 07:33 AM
460
Jul 9, 2005 10:05 AM
