Kingpin Troubles
Old Apr 5, 2008 | 04:51 PM
63maroontruck's Avatar
63maroontruck
Kingpin Troubles
I have a 63 F-100 and when I did the brakes I noticed that there is a bit of a wobble in the kingpins. Where can I get a kit, how much is it, and how hard is it to replace them?
Old Apr 6, 2008 | 07:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
Original Ford part number:
B7C3111A .. King Pin Kit
Fits: 1957/64 F100 2WD
FTE sponsor GREEN SALES has 10 of these kits available.
GREEN SALES sells NOS (new old stock) Ford obsolete parts and is located in Cincinnati, Ohio.
800-543-4959
You will have to contact Green Sales to get their price, and you may need special tools to install the kingpins.
Old Apr 6, 2008 | 10:14 AM
rbaker6336's Avatar
rbaker6336
if you use the plastic bushings that were oem the job is simple with normally no special tools needed
I always prefered to have spindles fitted ith bronze bushings that last much longer but have to be done at a machine shop
Old Apr 6, 2008 | 10:39 AM
matt2491's Avatar
matt2491
Go with the bronze bushings.
Old Apr 6, 2008 | 11:48 AM
NumberDummy
1957/64 F100
B7C-3111-A .. King Pin Kit came with STEEL & BRONZE BUSHINGS ONLY.
Nylon bushings were not available for 1957/64 F100's.
4) B7C-3110-A .. King Pin Bushing-STEEL & BRONZE
1965 and later king pin bushings were either steel/bronze or nylon.
FordStolz68
May 4, 2016 09:08 AM
Marklea
Apr 13, 2016 02:14 AM
RickyBR
Dec 13, 2004 07:45 AM
tankbuster71ford
Sep 4, 2004 04:24 AM
cccc1
Apr 20, 2000 07:22 AM
