Sponsored by: Auxito
Tranny Fluid Leak
Old Apr 5, 2008 | 05:05 AM
bowdog's Avatar
bowdog
Cool Tranny Fluid Leak
I changed my tranny fluid and did a complete flush. Every thing went smooth with the exception that I noticed a puddle of new tranny fluid when putting new fluid into the fill tube. I crawled under to see where it was coming from and the filler has a little hole rotted through down near the tranny, where the tube starts to bend a little.
How hard is it to put a new one in? How do I tackle this? Any info would help. Thanks
Nowdog
Old Apr 5, 2008 | 06:14 AM
bowdog's Avatar
bowdog
I looked in the haynes manual and I see no where in there that it talks about replacing the transmission dipstick filler. I am really getting disgusted with this ford truck!!
Old Apr 5, 2008 | 08:11 AM
steve(ill)'s Avatar
steve(ill)
why bother to change it? just take a little sand paper and rub back and forth over the hole to scuff it ut. wipe it off with acetone or a non oily cleaner, then put a dap of JB weld or liquid metal etc over the hole. You could probably even use RTV since there really is no pressure in the tube.
Old Apr 5, 2008 | 10:15 PM
streethealer's Avatar
streethealer
2nd vote for the JB weld. IT's cheap and easy.
Old Apr 5, 2008 | 10:31 PM
LxMan1's Avatar
LxMan1
It should have one retaining bolt on the back of the engine (usually a bellhousing bolt) and just a tight fit from an o-ring at the tranny.
But if it is accessible, I also would JBWeld it.
