Why me?
Old Apr 4, 2008 | 06:53 PM
sflem849's Avatar
sflem849
Originally Posted by F350-6
So far it seems the consensus is to go enjoy a cold one. I like that idea.
When you get back to cussin, I mean looking at the spare tire thing, make sure you didn't lower it down too far. The cable needs to have some tension on it when you wind it back up so it doesn't ball up and cause a bind. Maybe try lowering the cable back out with someone pulling on it to take the slack out. Then apply a little tension on it as you wind it all back up.
Good idea! I have also heard there is quite a bit of wiggle room for the tire. Have that same assistant line it up where it needs to live.
Old Apr 4, 2008 | 07:38 PM
RussB's Avatar
RussB
with the stock size spare there should be a bunch of room in there to move it over slightly ????? NO ????? You have probably got that one covered already eh ???
Old Apr 4, 2008 | 08:16 PM
big poppa's Avatar
big poppa
Well chase, remember i told you i looked into that crystal ball i have and said you,ll have the exhaust in, I THEW IT OUT THE WINDOW, some teller i am. hope everything works out from here on in.
Old Apr 4, 2008 | 08:44 PM
superduty4x4's Avatar
superduty4x4
It's winched up in there tight now, all the way against the little stop on the pass. side and the driver's side tailpipe is mashed between it and the shock (and not in the right position either).
Currently enjoying said cold one and much happier than before Rather than stacks, I think I'll just return it to a straight pipe
EDIT- forgot to add- yes I'm installing duals- Diamond Eye 4" turbo back aluminized.
Old Apr 4, 2008 | 10:20 PM
SVLERF250PWRSTRKE's Avatar
SVLERF250PWRSTRKE
Throw that spare in the bed
Old Apr 4, 2008 | 10:23 PM
superduty4x4
Not gonna happen- too much trouble and I need all the room I can get with the shorty anyways.
svt2205
2009 - 2014 F150
Aug 10, 2012 03:45 PM
blloyd
Apr 24, 2011 12:04 PM
Birdhater
May 7, 2009 02:37 PM
superduty4x4
20
Apr 7, 2008 03:28 PM
Stangfire
1997 - 2003 F150
May 3, 2004 11:11 AM
