jacking up motor 360 fe
Old Apr 5, 2008 | 06:54 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The retainer, if there is one, is used to keep the shaft from being removed from the top, but I believe it is better to remove the shaft.
Or at the very least remove the distributor, remove the shaft and pump together, then reinstall, and drop the distributor back in. Way too easy to get the alignment of the shaft, pump and distributor bunged up otherwise.
Old Apr 5, 2008 | 07:00 PM
brownfoot's Avatar
brownfoot
you may be correct, it's been over 15 years since I had it apart
doesn't get driven much, only 11,000 since rebuild
but don't recall any issues and am sure the dist. was not removed
Old Apr 6, 2008 | 09:46 AM
private-aye-fish's Avatar
private-aye-fish
Exclamation Carb linkage
Ram, If you do jack or lift it up remember your carb linkage and disconnect as it can bend while lifting engine.
Old Apr 6, 2008 | 11:56 PM
ramarado's Avatar
ramarado
Well, a hoist sounds great but my shop is a dirt floor, I'm in Arkansas. LOL
Seriously, a concrete floor is in the plan, just need to quit spending money on the truck and get the shop finished. The truck is just more fun!
As far as the hex shaft, it stayed in with no problem, and no stress on the shaft at all. The dist couldn't turn as it was still connected to the cam and I put the timing chain on first so I couldn't have turned the dist if I'd tried. I also aligned the shaft to the pump B4 I put the pan back under, so that I didn't have to twist the pump with the pan in the way.
Anyway, now all I have to do is re-set the timing. Seems a little off now that I have the new chain on.
Old Apr 7, 2008 | 01:26 PM
Bullitt390's Avatar
Bullitt390
Here is a pic showing the oil pump shaft retainer compared to one that came without.
