Front drive shaft trouble help!!
I've got a f-250 sd crew cab diesel 4x4. The front drive shaft well the cvc part of it is all rusted and broke. What's the best way to fix it? I've had a couple mechanics look at it they say to just put a whole new shaft on? I've priced around there like 400 bucks. Any suggestions? Is there somewhere i can get a good used one or a place that would be cheaper? Thanks.Donovan
The CV is just a double u-joint - goto to your local Ford, NAPA or similar place and see if they have a complete kit for it.
Unless, of course, the flange or the shaft loops are destroyed, then you might be better off with a new shaft.
Also, check for driveshaft shops in your area - they can probably rebuild it cheaper than new.
stlrisk
Jul 3, 2013 10:05 PM
northerndave
Dec 7, 2012 08:59 AM
NemesisNJ
17
Aug 5, 2011 05:52 AM
JimJ
1983 - 2012 Ranger & B-Series
Aug 29, 2003 01:13 PM
