Offroad & 4x4
75 disk breaks
Old Oct 5, 2004 | 04:37 PM
Blueoval_boy_64's Avatar
Blueoval_boy_64
75 disk breaks
Will the disk breaks on my 94 swap on to the 75 axle i'm getting?
Old Oct 5, 2004 | 09:25 PM
fishmanndotcom's Avatar
fishmanndotcom
cross reference part numbers at napa and see...i dunno, wouldn't take long
-cutts-
Old Oct 5, 2004 | 10:50 PM
Skipped_link's Avatar
Skipped_link
had to rewrite this (read before you write ) is it a F-150 250 350? need moe info, (Help us help you)
Old Oct 5, 2004 | 11:03 PM
Blueoval_boy_64
they are both F-150's
Old Oct 5, 2004 | 11:05 PM
Skipped_link
Is the 75' already disk or is it drum?
Old Oct 5, 2004 | 11:12 PM
Blueoval_boy_64
the 75 is drum
Old Oct 6, 2004 | 12:32 AM
Skipped_link
I think your S.O.L. if I remembler correctly most of the drum brake D44 axles had six bolts bolting the caliper mount and spindle to the knuckle and your 94' TTB has five, also on the newer front ends the caliper mount is cast as part of the knuckle, if your 75' front diff is an open knuck housing & you feel like experimenting you could see if you can put the entire knuckle from your 94' on the 75' housing (from the ball joints out,) I cannot tell you this will work for sure, I've never tried it, even if the 75' has the five bolts holding the spindle on you will have to find caliper mounts & calipers, if the 94' knuckle assembly will not fit the older diff your best bet would be to find a late 70's diff that already has disk brakes,
Let us know how it works out,
Old Oct 6, 2004 | 05:32 AM
wyldstallyn73's Avatar
wyldstallyn73
94 knukles wont fit the 75, sorry. But if I remember correctly, my early/mid 80's broncos have a 6 bolt spindle pattern that looks very close to the 6 bolt drum brake pattern, so maybe the 94 has the same 6 bolt pattern seeing as they are the same general suspension.
smadden
Sep 6, 2015 09:17 AM
smadden
Robert Moore
Jul 2, 2015 08:11 AM
junior high teacher
1947 and Older Ford Trucks
Jun 1, 2011 06:31 PM
mikef56
1997 - 2003 F150
Oct 25, 2006 11:53 AM
