Heads installed backwards??
Old Apr 2, 2008 | 11:54 AM
fordfan302's Avatar
fordfan302
Well I went a made the biggest mistake of the century, I installed my heads backwards I really dont want to tear the motor down again I have it almost complete except for the front accessories...Now the only difference that I know is the emissions exhaust hole on the side of the head is on the front now, and since I dont have a cat converter I can just ditch all the emissions stuff and plug off the hole right????
Old Apr 2, 2008 | 12:16 PM
durk's Avatar
durk
I used a 5/8" threaded insert with 7/16" threads inside.That allowed all my acc. to bolt up.
Old Apr 2, 2008 | 12:37 PM
fordfan302's Avatar
fordfan302
Where could I get something like that???? Thats definately what I need
Old Apr 2, 2008 | 09:41 PM
fordfan302's Avatar
fordfan302
Will the factory inserts come out of the heads??? If so, how to get them out?? I have them on the back side and If I could remove them and use them in the front Ill be trouble free
Old Apr 3, 2008 | 08:47 AM
jas88's Avatar
jas88
I would have thought the intake runners would not line up like that.
Old Apr 3, 2008 | 10:00 AM
durk's Avatar
durk
I got my inserts from a local nut and bolt shop.
Old Apr 3, 2008 | 11:22 AM
fordfan302's Avatar
fordfan302
The hell with it, the motor is coming apart again, You guys recomend I get new head gaskets??? Even though the motor has never been run???
Old Apr 3, 2008 | 12:57 PM
jjstanza's Avatar
jjstanza
Yes new gaskets are in order. Not running the engine doesn't matter. You torqued the heads down during install and crushed the gaskets to some degree and they should not be retorqued.
Old Apr 3, 2008 | 02:44 PM
ssidney's Avatar
ssidney
probably cheaper just to get the inserts
Old Apr 3, 2008 | 06:30 PM
mattri's Avatar
mattri
A NPT plug is a couple of bucks at most, why not just plug the hole instead of pulling the entire motor?
Old Apr 3, 2008 | 06:38 PM
fordfan302's Avatar
fordfan302
Well guy 5/8 is what Durk said and thats just way to big, Im thinking 1/2 threads on the outside and 7/16 on the inside, If thats wrong let me know...Where could I get an insert that size?? Or where could I get an insert in general??? Carquest maybe?? Any special tools I need to install the insert??
Old Apr 3, 2008 | 06:54 PM
fordfan302's Avatar
fordfan302
Side by Side the heads are identical, the only difference is the air pump hole on 1 side of the heads and thats facing the front on mine...Hopefully I can just get these inserts I need and this motor will be ready to drop
Old Apr 3, 2008 | 07:12 PM
jjstanza's Avatar
jjstanza
You can get NPT (National pipe thread - Wikipedia, the free encyclopedia) fittings at any good hardware store, in the plumbing department.
Old Apr 3, 2008 | 08:04 PM
HemiEater's Avatar
HemiEater
drill the bolt hole on the accessories
Old Apr 4, 2008 | 07:41 AM
durk's Avatar
durk
mine are 5/8". I am running e7te heads.
