6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Dealership inspecting the DPF?
Old Apr 2, 2008 | 10:00 AM
BTXpress's Avatar
BTXpress
Not sure if anyone else is having problem using the search feature, but I keep getting errors.
I took my truck in for its second oil change and to check a few other things:
1. They replaced a back up light previously; however, it is not as bright as the original. When driving the truck, it is difficult to tell if it is even working.
2. Check recall on driver side seat.
3. Reverse aid sensors, not all working
4. Check and verifty the DPF is not cracked, my exhaust is not black with soot; however, its definitely not as clean as when we bought the truck.
I received a call stating the truck was ready, except the Diesel Tech says my truck does not have a DPF. DPFs are only on gasoline engines.
I was hoping to find some earlier posts I have read concerning cracked DPFs, etc. so I could explain to him! I know my dealership did not have a certified diesel mechanic a few months ago.
I wanted to document with the dealership, that I wanted the DPF checked... however, now I am concerned should I have true engine/exhaust problems, will they be properly taken care of.
Sorry for the ramblings, what are your thoughts on this?
Thanks,
BT
Montgomery,AL
Old Apr 2, 2008 | 10:05 AM
tr0y's Avatar
tr0y
"I received a call stating the truck was ready, except the Diesel Tech says my truck does not have a DPF. DPFs are only on gasoline engines."
Be Afraid Very Afraid ..... I would think just maybe a new service center would be in order.
Old Apr 2, 2008 | 10:10 AM
mastercaster's Avatar
mastercaster
find a another dealer, and FAST. any respectable tech should know that all new diesel have a dpf, diesel certified or not!! but, if you have any real problems, you'll want a good certified tech to do the work. i personally wouldn't even let a dealer change the reverse light. takes them 4x as long and they have a descent chance of screwing something as simple as that up. here is one link for you...
https://www.ford-trucks.com/forums/6...f-problem.html
Old Apr 2, 2008 | 10:13 AM
jshumadine's Avatar
jshumadine
To my knowledge, DPF stands for Diesel Particulate Filter. Not sure where that guy is getting gas from...
Old Apr 2, 2008 | 10:22 AM
serviceguy's Avatar
serviceguy
you are correct DPF= Diesel Particulate Filter. Find a different dealer and fast!! before they really screw something up.
Old Apr 2, 2008 | 10:45 AM
WhëëlMå1's Avatar
WhëëlMå1
I could have sworn it meant Dodge Killin' Performance Feature
Old Apr 2, 2008 | 11:49 AM
BTXpress's Avatar
BTXpress
Thanks Guys. This was my initial concern when I wanted to get the first oil change and was told they did not have a diesel tech. I just got done re-reading about the "ticking noise." I had that for a couple hundred miles after the first oil change, and I am hoping that it doesn't come back after this one.
Mastercaster... thanks for the link, that was the thread I was looking for, but I am unable to search the site.
BT
Old Apr 2, 2008 | 03:01 PM
fordfish's Avatar
fordfish
that's wack
Old Apr 2, 2008 | 06:50 PM
kawtiper's Avatar
kawtiper
get that in writing ........then send it to ford corp.
Old Apr 2, 2008 | 10:12 PM
SANDDEMON08's Avatar
SANDDEMON08
Are you kiddin me, is this some kind of aprils fool ****, WWWOOOWW!
Sorry,bro find a new dealer
Old Apr 3, 2008 | 12:00 AM
spatel23's Avatar
spatel23
Like everyone said, check all the work they have done previously and find a new dealer FAST.
one thing you may want to make sure of, what kind of oil did they use.
Ask to see the dispenser and check it for the correct CJ4 labeling yourself.
If they didnt use the correct oil- you know what to do.
hope all turns out well for you.
good luck
Old Apr 3, 2008 | 01:07 PM
fordfish's Avatar
fordfish
my next question...how do dealers NOT know about the DPF...and the EPA is sending out teams to check for DPF deleters...
Old Apr 3, 2008 | 02:10 PM
supeRobertduty's Avatar
supeRobertduty
Good Question
Old Apr 4, 2008 | 06:19 PM
Tom Hoffman's Avatar
Tom Hoffman
If you need a good Tech I can get you my techs number
My truck is still in the shop and it has been in over 26 days since I bought it
and he has replaced over 10 items, he must be good by now!!!
The only problem is he still can't fix mine
Old Apr 4, 2008 | 07:00 PM
kimminau2's Avatar
kimminau2
Do you have any confirmation that the EPA has "teams" out to check for DPF deleters? Have they checked your DPF? Have they checked the DPF of someone you know? Did someone reliable at least tell you that THEY had been checked? Not trying to be an *&^ just wondering before an innocent statement creates a panic.
