Brake problems!! I need help!
Old Apr 2, 2008 | 08:04 AM
cgrandahl64's Avatar
cgrandahl64
A brake problem that is really getting to me.
I will start with all the information leading up to this situation...
I was hauling a heavy load of lumber to the cabin with my rig (in my signature) when I hit the brake and they felt a bit mushy. I got out and checked around a bit and one of the lines that runs from the master cylinder to the proportioning valve on the frame rail had busted open (rusty). I was in the middle of a 400 mile one way trip so I decided to be clever and use a vise grip and pinch this line off. I cut through what was remaining and slowly crimped it down for about an inch. This stopped the leak completely. I figured this way I would have at least one set of brakes.
As soon as I got to driving again, the brakes were nearly impossible to depress. No matter how hard I hit the brakes the truck slowed down very slowly. (not good). I think, and correct me if I am wrong, this is because I had about a 2 foot section of brake line leaving the master cylinder that's was pinched/blocked off so the piston in the cylinder couldn't travel very far. Does this sound right?
I nursed it home, and replaced the line and bled the brakes to get all the air out of it. It took a while to get the air out, but I am confident it is all out of the system now.
Problem is, my brakes are still very mushy. No matter how hard I try to press the brakes the truck does not slow down very fast. On gravel I cannot lock up any of the tires. The ABS light is not on but the brake light remains on.
I am wondering if it possible to damage the master cylinder? Or is the proportioning valve stuck? What could be going on?
Also,
How much vacuum should the vacuum pump be making (the pump that drives the master cylinder power assist?
Thanks in advance, and sorry for the long post, but I need help!
Old Apr 2, 2008 | 08:49 AM
haroldrussi's Avatar
haroldrussi
If I remember correctly there should be a reset button on the proportioning valve that will recenter it then you have to bleed the brakes again and it should work. If not get them pressure bleed by one of the shops that have the equipment to pressure bleed the system. Good Luck
Old Apr 2, 2008 | 12:50 PM
PLC7.3's Avatar
PLC7.3
On the 93 you have a RABs valve........on the frame left foot area... You need to bleed it after both rears are done...... Check electrical connections on the M/C and the foot brake for the red light....... Vacuum pump should give 21"HG at sea level.
If you would like the Vac pump test and 93 RABS info click on my name and email me.
Subject: RABs 93 and Vac test
Lazy K's Avatar
Lazy K
Sounds like you still have air in the system. If your truck has RABS then I would think the proportioning valve is in the RABS valve block on the inside of the left side frame rail. You can recenter it if necessary by opening a front bleed screw and pressing the brake pedal. Your brake light should then go out. If your booster vacuum was OK before this happened I would think it is still OK.
Old Apr 2, 2008 | 03:14 PM
cgrandahl64
Can I assume the RABS valve is not stuck in postion if there is pressure at both the front and back?
Old Apr 3, 2008 | 07:15 AM
Lazy K's Avatar
Lazy K
The RABS valve only effects the rear brakes so if you have pressure there you are OK. Apologies for previous post. I had been doing some work on a Chevy truck which has a pressure differential switch and it is necessary to open a bleed screw on it to center it. Does not apply to Ford. I still think you need to keep bleeding it.
Old Apr 3, 2008 | 07:32 AM
PLC7.3's Avatar
PLC7.3
Lazy K the older Ford trucks before RABs have a proportioning valve that requires resetting after bleeding usually.... anytime there was a substantial difference in pressures between the systems it would shift and illuminate the brake light.
Old Apr 3, 2008 | 11:58 AM
Lazy K's Avatar
Lazy K
Apologies yet again. What I should have said in last post was......"Does not apply to your Ford." I`m now wondering about Altzheimers.
Old Apr 3, 2008 | 03:23 PM
cgrandahl64
Update time.
I bled the entire system. Bench bled the M/C, put it back on, and bled the RABS valve, then RR, LR, RABS again, RF and then LF. I bled about a gallon of brake fluid through the system; I cannot find any air anywhere. The pedal feels very firm, and I can apply pressure and it depresses about 2 inches then feels very firm. When I try to drive the truck, I can mash the brakes and the pedal goes almost all the way to the floor, and the truck stops, but very slowly. I cannot lock the tires up on gravel. The red brake light is still on.
Calipers, rotors, drums and shoes are only about 6 months old, (5k miles) and they were on the rig before this problem started and worked fine.
I am going to replace the M/C just to see, but does anyone have any other ideas?
Thanks,
Clint
Old Apr 3, 2008 | 03:31 PM
fuzzy1626's Avatar
fuzzy1626
Originally Posted by cgrandahl64
Update time.
Clint
Is this with the engine running but the truck not moving, or engine not running?
Old Apr 3, 2008 | 04:38 PM
PLC7.3's Avatar
PLC7.3
Rear brakes way out of adjustment can cause your low pedal problem also....... If the vac pump is working correctly, is the booster working .... check the check valve on the booster. To check a M/C, pump the pump quickly several times to see if it rises...... if it does the internal lip seals may be worn allowing a fluid bypass. Remember our vac pump supplies just enough vac for about 4 pumps at higher RPMs..... there is no accumulator to store vacuum on the newer trucks.
Old Apr 4, 2008 | 11:26 AM
cgrandahl64
Good news. I have good brakes now!
1. Replaced the M/C - brakes got a little better, no fading to the floor anymore.
2. Tightened rear brake pads, both way out of adjustment, brakes improved a lot.
3. Measured vacuum from pump, only at 7 in hg, replaced vacuum pump, now brakes work great. Perfect response, very easy to push, anit-locks in rear work great, truck stops on a dime!
Thanks again for everyone’s help!
ExpyDude99
1997 - 2003 F150
Jul 21, 2015 12:02 AM
Holehawgg
Jan 6, 2015 01:17 PM
dmccorkle911
18
Aug 3, 2014 03:24 PM
fl-mitchells
16
Mar 15, 2013 01:43 PM
Knucklebuster
17
Apr 1, 2007 07:05 PM
