head Gasket?
Old Aug 31, 2002 | 07:58 AM
tamarackstyle's Avatar
tamarackstyle
head Gasket?
I have a rebuild 351w with about 4000 miles on it, and I am losing oil into the cooling system, but no coolant shows up in the oil. Its bad enough to where I have to add two quarts of oil or more when she is low. Can someone please tell me why I would leak one way but not the other. And how can I diagnose this problem to be a head gasket or something more serious, with a compression tester and vacume gauge. Thank you.
Old Aug 31, 2002 | 08:47 PM
Mike W's Avatar
Mike W
head Gasket?
Hi, are you sure the oil is getting into the coolant? I have seen coolant getting into the oil before due to a head gasket problem. A head gasket could not cause your problem because the oil for the rocker arms comes from the pushrods.
Old Sep 7, 2002 | 06:07 AM
tamarackstyle
head Gasket?
yeah Im preatty sure. The oil is going somewhere and its not on the ground. I poped the cap to the radiator and its oily in there. I was wondering since the oil comes from the pump to the lifters, thru the pushrods and to the valve train, and then drains back down to the pan if I wouldnt have a pushrod problem. It seems to me that in order for the oil to be making its way to the coolant and not vis-a-versa that the preasure would have to be greater on the oil end. then again if I had a pushrod problem It would show up in valve train noise you would think. I would be grateful to any more suggestions or thoughts on this. thank you.
Old Sep 7, 2002 | 09:57 AM
cajunbronco's Avatar
cajunbronco
head Gasket?
genscripter
26
Jul 11, 2016 02:16 PM
gameover1974
19
Dec 18, 2015 02:15 PM
MudDan
13
Jan 13, 2012 01:06 PM
mr.fordneck
Jan 7, 2011 11:07 AM
onebadb1
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 7, 2010 11:15 PM
