Pulling engine on F600
Old Apr 1, 2008 | 09:20 PM
kfire01's Avatar
kfire01
Anyone have experience on pulling the motor and tranny together on an 1969 F600? can it be done? Any out of the ordinary headaches involved.
Thanks.
Old Apr 2, 2008 | 03:21 PM
Freightrain's Avatar
Freightrain
I suppose the only problem you might have is getting the tranny up/out of the hole. Tilting the motor enough to get it out. I suppose if you pulled the front sheetmetal(or at least the grille/core support) would make it easier.
Old Apr 2, 2008 | 04:21 PM
blue68f100's Avatar
blue68f100
I've done it on my 68 without any problem. If I recall the radiator must be out for clearance.
Old Apr 3, 2008 | 02:36 PM
Freightrain
Blue68f100......this is a F600, not a F100. Slightly larger tranny(likely?), which is why I was concerned with getting it out in one piece. It might come out easily, but something to think about.
I've had my F100 apart a bunch of times(with tranny), but it's only a toploader 4spd(not a truck 4 spd). Radiator always has to be outta the way.
Old Apr 3, 2008 | 03:31 PM
blue68f100's Avatar
blue68f100
Mine has the C6 auto which I recall is slightly longer than a manual. If you can raise the body to give extra tile may help too. Is the cross frame centered under the engine or toward the back? I sure like stabbing trannys when I'm not under the cab. Where I can easly align things up. But if you have a tranny jack it may not be to bad.
pinn600
Large Truck
Jan 30, 2014 10:12 PM
pinn600
Large Truck
Dec 7, 2013 10:52 AM
56f600
Engine Swaps
Feb 24, 2005 07:15 PM
gypsybill
Jul 24, 2000 08:40 AM
Kid
Mar 24, 2000 02:47 PM
