F-600- 14 or 15 inch brakes?
01-27-2014, 02:21 PM
on
Hello Forum,
Does anyone know of way to determine the brake size on 68 F-600 without pulling wheel and drum? Any help will be appreciated.
Thanks
01-30-2014, 03:04 AM
Quote:
Originally Posted by
pinn600
Post the AXLE code stamped on the Warranty Plate, located on the left door face below the latch.
01-30-2014, 11:22 AM
on
Hello Number.
Under 'AXLE' it has "F7". Hope that's what you need.
Thanks a lot
01-30-2014, 11:40 AM
pinn600
F7 = Eaton model 13802 2 Speed Rear Axle / 5.83/8.17 /
15 ,000 lbs. Rear Axle Capacity.
1968 F600: With a 15,000 capacity, rear brakes could be 15" x 4"
or 15" x 5."
When there is no 3rd digit of the axle code, the 'standard equipment' front axle's weight capacity is
5 ,000 lbs. = 14" x 2 1/2" front brakes.
01-30-2014, 10:12 PM
on
Just wanted to thank you again for the info.As always,you have been a great help.
dulcevendetta
Large Truck
15
04-28-2020 04:37 AM
daltonhawk
WTB - Parts & other
09-28-2017 09:29 AM
jackdog06
08-16-2015 05:07 PM
1975-F6004x4Dump
Large Truck
01-27-2014 11:47 PM
69800
08-27-2009 05:00 PM
