6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Oil Filter Change???
Old Apr 1, 2008 | 09:13 PM
fordsd350's Avatar
fordsd350
Help the stupid new guy!!
My filter came with a "core adapter", is this needed on a 6.4?
Is there a trick to getting the filter back in; i.e. depressing the spring?
Old Apr 1, 2008 | 09:20 PM
origcharger's Avatar
origcharger
If your filter came with a core adapter take it back and get a Motorcraft or Fram. They should fit and function as OEM intended.
Old Apr 1, 2008 | 09:26 PM
fordsd350's Avatar
fordsd350
I have a STP (S9549) and the instructions for the adapter all reference a 6.0. So you are probably right about going with a motorcraft.
How about the spring compression? The new filter looks physically identical to the old filter, but I can't seem to get it seated enough to engage the cap's threads.
Old Apr 1, 2008 | 09:34 PM
origcharger
Really, I would not use the STP filter.
Get a Motorcraft or Fram and snap it in the lid, then install it, should not take excessive force to get threads engaged.
Old Apr 1, 2008 | 09:38 PM
fordsd350's Avatar
fordsd350
Thanks again, guess I'll leave until tomorrow and I have the right filter.
Old Apr 2, 2008 | 09:15 AM
69cj's Avatar
69cj
"Never-Ever" use will fit filters on the 6.0 or the 6.4. You are flirting with disaster. Use only Racor made filters!
Old Apr 3, 2008 | 07:50 PM
bnmccoy's Avatar
bnmccoy
Check out this thread and the links to other threads withing this thread...
https://www.ford-trucks.com/forums/7...n-filters.html
Old Apr 4, 2008 | 05:16 AM
rmosso1's Avatar
rmosso1
Tip:
I almost messed up a couple times as the top of the old filter would remain in the covering canister. Then you have to place excessive pressure to retighten the canister. Best advice: Make sure the element being removed is identical to the new element and use motorcraft or fram. The oil filter for the 6.0 and 6.4 are identical.
Old Apr 6, 2008 | 08:43 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
I pick up my filters from my local international truck dealership for less than $18
Part# 1840752C91
Old Apr 21, 2008 | 10:39 PM
caprang's Avatar
caprang
"The oil filter for the 6.0 and 6.4 are identical"
Any idea if the fuel filters are the same for the 6.0 and 6.4?
Old Apr 22, 2008 | 08:04 AM
captain_trucks's Avatar
captain_trucks
I've been using Donaldson filters on both my 6.0 and my 6.4. The 6.0 has well over 200,000 miles with no problems. I use them for oil, fuel and air. They do not have a fuel filter for the 6.4 yet. Fuel filters are not the same.
Bohen
6.7L Power Stroke Diesel
Feb 24, 2017 03:18 PM
TerranE
21
Jan 3, 2017 08:43 AM
1buckeyefan
Mar 29, 2011 11:17 AM
Scratcher
Jun 8, 2010 09:50 AM
racenitro
16
Jul 25, 2008 07:56 PM
