Lead foot death
Old Dec 31, 1969 | 06:00 PM
Guest
Guest
Posts: n/a
Lead foot death
Old Apr 9, 2002 | 12:45 AM
banausic's Avatar
banausic
Lead foot death
[updated:LAST EDITED ON 09-Apr-02 AT 01:48 AM (EST)]I've been working on rebuilding my girlfriends 86 Bronco after an engine fire on the way home frm buying it. I've got it all fixed up and running good, exept for on problem: If I floor it it stalls, and dies. If I feather the pedal it runs and accels fine, it just has a dead spot when accelerating about a quarter of the way down with the pedal.
It's got a 351w, Holley 4180, & a C-6
I've rebuilt the entire vacuum system, and replaced the distributor, and al lot of other things. A vacuum gauge flutters just a little when I hook one to a manifold vauum. Othe than that the damn thing runs great.
Any help would be great.....
Old Apr 9, 2002 | 12:50 AM
canadianfordman's Avatar
canadianfordman
Lead foot death
My 84 F150 351w does somewhat the same thing and I am just about to put an new ignition and coil in it. I will let you know soon.
Old Apr 9, 2002 | 08:52 AM
GendoIkari69's Avatar
GendoIkari69
Lead foot death
I have a similar problem until the engine reaches normal op temp. I put an MSD coil and ignition module in recently but it didn't not change. Still trying to figure it out.
Old Apr 9, 2002 | 11:39 AM
jwtaylor's Avatar
jwtaylor
Lead foot death
I had a problem similar to that, it would die if I pressed the gas in 1/4 of the way or more unless I put it to the floor. Replaced the carb and hasn't happened since. Good luck
Old Apr 9, 2002 | 01:43 PM
sauerf100s's Avatar
sauerf100s
Lead foot death
I could be wrong, but it sounds to me like you aren't getting enough of a squirt of gas from your accelerator pump on your carb. Did you rebuild the carb after the engine fire? Maybe the diaphram in the pump got scorched during the fire. You can check this by looking in the carb and opening the throttle by hand.(you probably know this) Anyhow, this would be the first thing I would check.
Old Apr 9, 2002 | 03:52 PM
ExplicitHP's Avatar
ExplicitHP
Lead foot death
A fluttering vac. gage would notmally lead me to believe there is a valve problem. But in this case i agree that it is a carburator/fuel delivery problem.
-Jon
Old Apr 9, 2002 | 04:50 PM
WrenchHead84's Avatar
WrenchHead84
Post Lead foot death
Has the fuel pump been replaced? Also, is the ignition timing correct?
WrenchHead
1979 F-150 Custom. 302 V-8 4-spd 2WD. 121,000 Miles
Old Apr 12, 2002 | 11:14 AM
airharley's Avatar
airharley
Lead foot death
Also check you choke setting. Some mornings I hit the gas and it almost stalls until the choke opens up more 2 minutes later.
Old Apr 12, 2002 | 01:15 PM
GendoIkari69
Lead foot death
I think I just solved my problem. I swapped the card with the one on my 85 bronco that I'm taking apart. The 85 had no problem running. While I haven't had the time to see how the start is on a cold and wet morning, it is already running better.
Old Sep 7, 2002 | 03:55 PM
banausic's Avatar
banausic
Lead foot death
Just thought I'd updat this thread. We had a $1100.00 valve job done and the culprit ended up being two burnt valves #'s 6 & 7. Runs good now, still doesn't run like a 351 HO should, bust a vast improvement.
Thanks Everyone for your help.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
