Interior Lights not going out..
Old Apr 1, 2008 | 01:11 PM
k7ikuzus1k's Avatar
k7ikuzus1k
Anyone have this issue?
Basically, the truck is thinking there is a door propped open somewhere. If you turn the engine off and get out of the truck, the interior light stays on like the door didn't close all the way, even though I go all the way around and make certain every door is tightly closed. Even check the barn doors and window.
Or reverse that, get in the truck and start the engine and the dash says there is a door open somewhere... Even though I have throughly checked that all doors are closed.
Is it possibly just one door imparticular? I don't see any bump switches like in older vehicles that the door pushes on to tell the computer if a door is ajar or not.. I'm assuming one of those has to be my problem, but where are they?
Old Apr 1, 2008 | 01:18 PM
PhantomRider's Avatar
PhantomRider
I believe on the newer vehicles they are inside the door but not real sure. You may have to pull off the door panel to get to it.
Old Apr 1, 2008 | 02:34 PM
HowieE's Avatar
HowieE
What year and model is the truck?
Old Apr 1, 2008 | 02:41 PM
k7ikuzus1k's Avatar
k7ikuzus1k
'02 V10 Ex XLT if it makes a difference..
Old Apr 1, 2008 | 03:31 PM
HowieE's Avatar
HowieE
I have the wiring diagram and thought I could help but Ford sure goes out of there way to make it hard.
The door ajar switches are inside the doors and there is no connector between them and the Vehicle Security System that you can get to to check the doors.
If you can find the Vehicle Security System module on the drivers side fender there are 3 connectors in line on this module. The one closest to the firewall is the door ajar connector, 2 rows of 7 wires each with a pink/black wire in position 1 and a black wire in position 14. Ford shows the door ajar switch as Normally Closed. with the doors closed I would assume pin 4, front drives door, pin 5 front passengers, pin 6 right rear, pin 11 left rear, pin 12 lift gate within the connector should all show continuity to ground. In any case they should all test the same. So if one is different that is the one I would investigate.
If this does not find the problem I would say yo have to look at the vehicale security system itself.
Old Apr 1, 2008 | 06:20 PM
aortizexcursion's Avatar
aortizexcursion
The latches on the doors are dirty. You need to clean them. I use rubbing alcohol and I believe some on here use WD-40.
Old Apr 1, 2008 | 07:23 PM
Monsta's Avatar
Monsta
Sit. Stay.
That's right! Spray the door latches down liberally w/WD-40 or similar. Open and close a few times afterwards.
Old Apr 1, 2008 | 07:34 PM
HowieE's Avatar
HowieE
What kind of electronics is this? What are you suggesting gets sprayed? Or is it just the fact that the latch does not move far enough to hit the switch?
I looked at the diagrams and see a normally closed switch.
Old Apr 2, 2008 | 04:47 PM
chazman's Avatar
chazman
hit the search button under interior lights;
https://www.ford-trucks.com/forums/6...taying-on.html
Old Apr 2, 2008 | 05:36 PM
HowieE's Avatar
HowieE
All right, what are we spraying? WD40 is a water displacer. What has gotten wet that requires this action? What is the door sensor . I can't envision a mechanical switch being effected by water.
Old Apr 2, 2008 | 05:45 PM
k7ikuzus1k's Avatar
k7ikuzus1k
my bad...
Have yet to find the time to take care of the problem, but this definitely sounds like it's my issue..
Old Apr 2, 2008 | 10:08 PM
AltaEx's Avatar
AltaEx
Old Apr 3, 2008 | 06:36 AM
DSMMH's Avatar
DSMMH
I had the exact same problem a month ago on my '04 X. Replace the "delay timer" relay.
DSMMH
Old Apr 3, 2008 | 06:44 AM
gecko5's Avatar
gecko5
Clean your latches... Had the same problem. Went around and thouroughly cleaned all the latches with cleaner (WD40 and Simple Green), problem went away. Had it come back last week. Did another quick clean on the barn doors, problem went away.
Old Apr 3, 2008 | 10:44 AM
k7ikuzus1k's Avatar
k7ikuzus1k
Well, I am seeing conflicting opinions here.. Not saying anyone is wrong, we all may have had different issues..
But, I did take the air compressor to all the latches yesterday and saw quite a bit of dust and debris come from all the latch mechanisms.
The rear barn doors especially... And I use them quite a bit. Not to mention go to the desert to ride dirt bikes quite a bit.. My truck sees lots of dirt.
Anyways, just blowing them out seems to have done the trick for now. Although I fully intend to lube them as well.. Don't want to use WD40 because although I agree with AltaEX and believe that it is the miracle spray, don't want to use it because the dirt will only stick to it later and pull it back in.. especially since I cant get in there to wipe off the excess.. Going to find a can of dry graphite spray.. I've used that in the past and it dries well I think.
