EGR deletion
Just like NPCCPARTSMAN, my turbo inlet tube was pretty gummy very quickly. I did the ccv re-route to a frame filter and back to the turbo inlet point. For vapor flow (no liquid traps in the hoses), there should be essentially no pressure drop so the crankcase should be operating at the same slight vacuum as stock.
The interesting thing:
After 1000 miles, I see no oil accumulating in the filter (nothing drains out). It is either being absorbed by the media until it gets saturated OR there just isn't much oil in the vapor. I guess it probably wouldn't take much oil to get things sticky.
I guess if I see a lot of oil in the filter after a bunch more miles, it would be a good indication of a need to go looking for the root cause! So if nothing else, it is a troubleshooting tool.
Vince - I guess I agree w/ you on the issue of having a hidden problem when the EGR valve plugs up w/ a lot of soot and oily solids. As indicated above, you list some of the problems that may exist - "behind the scenes".
My problem is that I am one of those that had oily solids in the valve and manifold - mainly in the UPPER section of the intake channel. I was not having any performance problems, but I wanted to see how the EGR valve looked. There were quite a bit of oily solids in fact. I was somewhat surprised. Since day 1 (almost) I have run good fuel, used Stanadyne, minimized idling (with the exception of last winter, but it was a Texas winter and not too bad), minimized short trips, occaisionally drove it hard, use synthetic oil, etc. I did just recently get the updated flash AND I routed the ccv vent through an oil collection filter - I am sure that these will help, but still a root cause probably remains. As you stated also - the ccv re-route is another band aid (one that I am very glad I installed).
Now I need to decide how to resolve the root cause since (as I stated), I agree that a normal EGR valve shouldn't accumulate oily solids like this.
How do I go about troubleshooting this? Shouldn't the dealership be responsible for looking into the root cause? I am still under warranty. I have a gut feel that if I take the dirty valve to the dealership (I have two valves and always keep one as a spare), they will not dive into the engine and try to see if I have valve seal problems, or ring problems, or valve cover baffle problems, etc. I would even bet that they would not be happy that I replaced the valve (at my own expense BTW). I realize that I do not know their reaction until I talk to them, but I think I know them well enough to "predict" their reaction.
The worst case scenario is that I pull and clean the EGR valve every 30,000 miles on my own. I have no issue w/ this, but if the dealership would be reluctant to help on this investigative effort, I can see why folks want to delete the EGR completely.
For me, I have no issues w/ the 30,000 mile swap, but it really shouldn't come down to that.
Please let me know what ya think!
Edit - I am not losing enough oil to even notice a level change in 5000 miles, so my root cause problem is clearly not big now. BUT ........... it is apparently enough to show up as a lot of oily solids. Enough solids in fact that I feel sure I would eventually have EGR sticking problems.
Even w/ this dilemma - man I love this truck. It is running great.
Clearly if exhaust gasses are dirty enough to start coating the EGR valve, they will be impacting the turbo vanes and the wheel on the exhaust side. Rust and dirty exhaust gasses are both issues w/ the possibility of having stuck turbo vanes. Keeping the exhaust gasses as clean as possible is obviously a very important task. This is one reason I am skeptical of the "two cycle oil as a fuel additive" concept. This is also why I choose to add a fuel additive that is designed to aid combustion.
I also have chosen to route the ccv vents through a filter (and recommend this) but I am curious about other possible sources of oil leaks into the combustion process. Would a dealership help troubleshoot this solely from the appearance of oily solids in the EGR valve?
Back to EGR ..........................
Now knowing that the EGR cooler issues are water side issues, a clean exhaust gas to recirculate is important because (in agreement w/ mrjc):
1. Clean exhaust, whether recirculated or not, is better for your turbo.
2. The EGR valve will not stick in the wrong position and cause performance issues.
Still wondering about the best way for a vehicle owner to troubleshoot the root cause (not symptom) of an oily EGR system.
